HELP with tranny, shift rod came out |
machina |
Apr 1 2007, 01:31 PM
i removed the plate on the tranny that holds the shift rod and the whole selector rod (the one that goes up into the tranny case) came out (IMG:style_emoticons/default/blink.gif)
how do i get this thing back in there? it looks like a giant key btw. i don't remember what position the selector was in when it came out. |
LowGT |
Apr 1 2007, 01:39 PM
1.8 and Proud! Group: Members Posts: 583 Joined: 2-October 05 From: Wylie, TX Member No.: 4,904 Region Association: Southwest Region |
It will go back in, you just have to wiggle it around a lot. It's easiest to do when the car is in neutral, but you can still do it if it's in a gear. Worst case scenario, just get it in there and then get the car to neutral and redo it.
Rough_Rider |
Apr 1 2007, 06:24 PM
Smurf Zone Group: Members Posts: 525 Joined: 16-August 04 From: Beaverton, OR Member No.: 2,547 |
If the tranny was in neutral the key piece should be pointed towards left side of car.
The whole thing wiggles back & forth thru a 30 degree arc. But you can also push the selector rod in & out. If tranny wasn't in neutral, do a search for Dr Evil thread on reassembling tranny, there's a picture of how to get the selector arms back to neutral with a screwdriver. |
machina |
Apr 1 2007, 07:10 PM
If the tranny was in neutral the key piece should be pointed towards left side of car. The whole thing wiggles back & forth thru a 30 degree arc. But you can also push the selector rod in & out. If tranny wasn't in neutral, do a search for Dr Evil thread on reassembling tranny, there's a picture of how to get the selector arms back to neutral with a screwdriver. yes, thanks. i had to move the sliders with a punch to get them into neutral and then all was fine. i got a good deal on this tranny (i have 3 now) but the shift plate was cracked so i had to swap it out. we'll see if the synchros in this one are any better than the one i pulled. |
Lo-Fi Version | Time is now: 15th May 2024 - 01:19 PM |
