Shift Fork Loose, Inside of Transmission? |
bd1308 |
Apr 4 2007, 05:07 PM
Apparently there is a shift fork inside of the transmission that selects the gears....
it's loose and i cant select anything... Unbelieveable... Is there a screw or something or am i looking at a replacement transmission The linkage set screws are toast too |
bd1308 |
Apr 4 2007, 05:13 PM
transmission is in neutral now, I suppose I should set it for a gear when i put that side shift console.
Bartlett 914 |
Apr 4 2007, 05:36 PM
transmission is in neutral now, I suppose I should set it for a gear when i put that side shift console. (IMG:style_emoticons/default/WTF.gif) Remove the cover for the shift console. Can you select a gear by moving the the shifter from there?. Is it loose there? If so remove the console. See it is is broken there. Not sure but I think the oil needs to be drained for this. |
bd1308 |
Apr 4 2007, 05:37 PM
Yes oil does need to be drained for this.
Time for a Britt drawing....(Eric loves these) |
Aaron Cox |
Apr 4 2007, 05:39 PM
cone screw backed out if you have no gears.....
TravisNeff |
Apr 4 2007, 06:24 PM
(IMG:style_emoticons/default/agree.gif) the set screw on your shift bar as it enters the engine compartment.
bd1308 |
Apr 4 2007, 08:57 PM
no Aaron, I checked.
The shift rod at the transmission was 180 degrees out. "I" would classify that as a failure at the transmission........... |
Joe Ricard |
Apr 4 2007, 09:02 PM
If you have a tail shift you can not just whip out there and quickly modify to side shift.
there are internal "things" that need to be changed. the rod for a tail shift can not be turned 180 degrees it is held in position by the shift forks. Unless you REALLY broke it |
Apr 4 2007, 09:03 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
take a picture and show me what you mean.
Show it from under the car, rear of the tranny. I have everything you need, including a cut away transmission case to reset the forks if you really have a broken or loose shift fork. Rich |
bd1308 |
Apr 4 2007, 09:21 PM
side shift
somebody quick with a transmission pic |
bd1308 |
Apr 4 2007, 09:30 PM
two pics ask two main questiosn of mine:
Dr Evil |
Apr 4 2007, 10:11 PM
Send me your transmission! Group: Members Posts: 23,001 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Not a set screw, its a roll pin. Did it shear?
Dr Evil |
Apr 4 2007, 10:12 PM
Oh ya, check my link for pics of how to check the shift forks and such through the shifter console hole. (IMG:style_emoticons/default/thumb3d.gif)
Eric_Shea |
Apr 4 2007, 10:17 PM
QUOTE Time for a Britt drawing....(Eric loves these) Whip it out Pablo! (IMG:style_emoticons/default/biggrin.gif) |
bd1308 |
Apr 4 2007, 10:18 PM
Not a set screw, its a roll pin. Did it shear? 99.5% sure now.... shifter shaft came 74% way out (IMG:style_emoticons/default/ohmy.gif) now to fix....new roll pin 2morrow |
Eric_Shea |
Britt... how come you have all the fun?? (IMG:style_emoticons/default/confused24.gif)
bd1308 |
Apr 4 2007, 10:22 PM
bd1308 |
Apr 4 2007, 11:12 PM
Thank goodness I get a Land Rover to drive around for five hours until the problem is fixed
lots of pics will be taken (IMG:style_emoticons/default/smile.gif) See you all tomorrow! |
John |
Apr 4 2007, 11:22 PM
Good Lord!
Some people have all the luck (an others none) I just hope your trans is ok inside with the selector and a roll pin loose in there. Did this happen while driving? What HORRIBLE crunching sounds were heard? When you drain the gear lube, I hope you don't find many many tiny bits of metal, but I suspect that you might. The roll pin can be replaced, but WHY did it fail? Was your car that hard to shift? Post some pics of the carnage. |
bd1308 |
Apr 4 2007, 11:30 PM
I will, but it was shifting very shallow-ly into 3 and 5 (not 1 oddly enough) and very deep into R,2 and 4.
Then i wasnt able to shift into 3 or 5 at all, but could shift into 1 fine, so i just used 1,2 and 4 until i got home. I was goign to limp over to my parents house to adjust my shift linkage, but then I had zero gears after trying to re-adjust my linkage. Eventually, **EVERYTHING*** in my car will either be brand new, or almost new. |
Lo-Fi Version | Time is now: 25th May 2024 - 03:17 AM |
