Heater for Water cooled 914s, As promised, here are the pics |
marks914 |
Apr 6 2007, 12:41 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Here are the pics of the prototype. If there is any interest, this may be one of my next produts.
It hets pretty cold here in Michigan, its 26F right now and I do need a heater. I had a heater under my dash and I got tired of looking at it so I came up with this. It uses the stuck heat/fan controls on the dash. The fan works in the usual way and the red heat director lever actuates the water control valve to control the temp of the heat exchanger. Mark Attached thumbnail(s) |
Mike Bellis |
Nov 8 2014, 04:45 PM
Sorry, I didn't see the question. Yes, in theory you should be able to flow a heater core from the inlet and outlet of the radiator. Flow will vary based on things like hose size, port resistance, parasitic drag, pressure differential, etc... But it should work. If you can find a Y fitting and point it the right direction (with flow) it should work better.
Like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-10496-1415486712.1.jpg) |
BRAVE_HELIOS |
Nov 10 2014, 10:27 PM
"Knowledge speaks, wisdom listens" Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Sorry, I didn't see the question. Yes, in theory you should be able to flow a heater core from the inlet and outlet of the radiator. Flow will vary based on things like hose size, port resistance, parasitic drag, pressure differential, etc... But it should work. If you can find a Y fitting and point it the right direction (with flow) it should work better. Like this... (IMG:http://www.914world.com/bbs2/uploads_offsite/www.usrallyteam.com-10496-1415486712.1.jpg) Thanks. I think I'll give it a try and see how it goes. What's the worst that can happen... no heat? Already there! |
Lo-Fi Version | Time is now: 19th May 2024 - 12:31 AM |
