Heater for Water cooled 914s, As promised, here are the pics |
marks914 |
Apr 6 2007, 12:41 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
Here are the pics of the prototype. If there is any interest, this may be one of my next produts.
It hets pretty cold here in Michigan, its 26F right now and I do need a heater. I had a heater under my dash and I got tired of looking at it so I came up with this. It uses the stuck heat/fan controls on the dash. The fan works in the usual way and the red heat director lever actuates the water control valve to control the temp of the heat exchanger. Mark Attached thumbnail(s) |
PinetreePorsche |
Apr 12 2007, 09:10 AM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
Yeah--where do you get the actual exchanger? Also--to do sourcing on the mystery wire, you COULD (your option--but exciting!) purposely short hot to ground just to see which fuse blows (maybe after first checking the red for current). Or, for the more prudent willing to spend more time on it, put a load into the line and check which fuse circuit shows current flow (what a drag).
Now about the origins of the exch. unit--new or recycled--if its not top secret? |
Lo-Fi Version | Time is now: 27th May 2024 - 02:47 AM |
