19mm Master Cylinder Question, What do I have here? |
AZ914 |
Dec 2 2003, 09:00 AM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
Ok, so I'm starting the install of my 911 front suspension and brakes. I have a 19mm master cylinder in a box, ready to install. So I pull the belly pan, roll under the car and stare up at my current master cylinder. I see an embossed '19' staring me back in the face. (IMG:style_emoticons/default/idea.gif)
It looks like its been there a while. Am I golden or am I missing something?! Was the 19mm ever an option on the 914? I held my new M/C next to it and they look identical, at least from the firewall out... Thanks! |
jonwatts |
Dec 2 2003, 09:25 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
The more important question is....
how much do you want for the new one since you already have a 19mm installed? (IMG:style_emoticons/default/smile.gif) Someone probably just went with the 19mm unit during a repair since it's such a common upgrade. A 4 cylinder car shouldn't / wouldn't have come with one. I don't know if the /6 cars used the 19mm master cylinder or not. I'm guessing they did since the rest of the suspension is 911. |
Mueller |
Dec 2 2003, 12:28 PM
If the M/C on the car looks old, I'd replace it, cheap insurance
for a while, the 19mm M/C unit cost less than a 17mm M/C, so that was one reason some people used the larger one for repair |
Dec 2 2003, 12:29 PM
Only the front suspension is 911 on the 914-6. The 19mm MC was used on them, though.
The 19mm is a direct bolt-in replacement for the 17mm, though you might have to move one of the brake lines a little? I forget. Sounds like someone already replaced your MC with a 19mm one. --DD |
AZ914 |
Dec 2 2003, 02:20 PM
Cool, looks like I'm set. I didn't see any leakage around the fittings so I'll leave that one in there and unload the spare.
Mueller |
Dec 2 2003, 04:20 PM
QUOTE Cool, looks like I'm set. I didn't see any leakage around the fittings they don't leak at the fittings (unless improperly installed), the fail internally which you cannot easily see....If you suspect the M/C of being older than 10 years or even just a few years old but not being used (as in car sitting around not running), I'd replace it now. |
Brad Roberts |
Dec 3 2003, 03:03 AM
If I recall correctly.. they dont say 19 on the side that you can see. (IMG:style_emoticons/default/idea.gif)
FIID. Delete that post. You dont want the hassle of dealing with someones loved ones after they buy a MC from you and they die in a crash. Throw it away. B |
Curvie Roadlover |
Dec 3 2003, 03:46 AM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(Brad Roberts @ Dec 3 2003, 01:03 AM) If I recall correctly.. they dont say 19 on the side that you can see. (IMG:style_emoticons/default/idea.gif) B True, the number is on the top when viewed from below. A royal PIA to see, as I recall. |
AZ914 |
Dec 3 2003, 08:49 AM
OK, staring up at the think, I see a '19'. However, the replacement I have has a '19' on the portion that is on the backside of the firewall, I believe.... ACK!
Should there be any noticable difference in the external construction (size, shape, layout) of these thigns as they look identical. Thanks! |
Joe Ricard |
Dec 3 2003, 09:44 AM
Side by side you can't tell the difference. As others have said if you are this far into it just change to the new one and have that piece of mind. Then buy my 320i calipers (IMG:style_emoticons/default/cool.gif)
AZ914 |
Dec 3 2003, 10:13 AM
HA.. thanks, maybe I will do that.. hopefully without too much aggrevation.
Joe.. I have the 911 calipers so you will have to find another buyer... (IMG:style_emoticons/default/beer.gif) |
davep |
Dec 3 2003, 10:28 AM
Here in Canada we started replacing the original master cylinders when the cars were 7 years old. That means they may be on their fourth master by now. Well, that may be a bit harsh, but I would think not too far off of the mark. I would think that torsion bars were not too far behind the masters in years to replacement. I have also replaced a lot of transmissions over the years. Rebuilding calipers has been quite a business also.
BTW: the cast sizes on the master cylinders are a rough guide to the bore size. For some reason the master cylinders are in "inch" sizes with increments of 1/16" 17 = 17.46 = 11/16 19 = 19.05 = 12/16 = 3/4 20 = 20.64 = 13/16 as used with 69 911S with aluminum "S" caliper DaveP |
fiid |
Dec 3 2003, 10:45 AM
QUOTE(Brad Roberts @ Dec 3 2003, 01:03 AM) If I recall correctly.. they dont say 19 on the side that you can see. (IMG:style_emoticons/default/idea.gif) FIID. Delete that post. You dont want the hassle of dealing with someones loved ones after they buy a MC from you and they die in a crash. Throw it away. B What post? Good point. Thx for the advice. |
John2kx |
Dec 6 2003, 09:20 AM
Senior Member Group: Members Posts: 502 Joined: 22-August 03 From: Augusta, Ga. Member No.: 1,066 |
Here is a post I saved that might shine a little more detail to this issue. I was in the same boat you were in last year........had new m/c in hand and found my car already had a 19mm installed. I would have replaced it at the time but the brakes worked great with the stock 914 calipers and my only reason for upgrading m/c was the installation of 911 calipers.
The brakes continue to work as expected after a year on the street and the new m/c has been added to my parts been for future use. http://forums.pelicanparts.com/showthread....?threadid=90929 John |
Eric_Shea |
Dec 6 2003, 10:28 AM
QUOTE Only the front suspension is 911 on the 914-6 Really!?!?! (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/laugh.gif) |
Eric_Shea |
Dec 6 2003, 10:34 AM
Oh... and good luck getting those rubber/stopper fittings back in. You'll wish you were never born! That ranks as one of the absolute worst wrenching tasks I've "ever" done on a 914.
If there's any tricks out there I'd be all ears cause I've got the 911 and the Gt project to go. I've resigned to leaving the tank out on the GT until I install the MC so as to make it easier. |
URY914 |
Dec 6 2003, 11:18 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,578 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
That's the way to do it.
Leave the tank out. Stick the hoses in the MC before you install it in the car. You're right- it could be the #1 PITA 914 job. (IMG:style_emoticons/default/ar15.gif) Paul |
Mueller |
Dec 6 2003, 11:46 AM
Not only leave the tank out, but loosen the two hoses that attach at the resivour, pull them down a few inches and it'll make life much easier
I put the rubber gromments in first in the M/C, then I push/twist the feed line into the rubber gromment. (lubed with some brake fluid) |
Rich Bontempi |
Dec 6 2003, 02:41 PM
914 Road Racer Group: Members Posts: 167 Joined: 5-February 03 From: Redwood City Ca. 94063 Member No.: 239 Region Association: Northern California |
The size of the master cylinder (17 or 19) is viewed on the under side of the master cylinder, but on the part of the master that is in the body work.You can't see what size the master is without pulling it out, or, MAYBE, having a really good set of eyes and a mirror and going in from under the pedal section in the car.(never tried that) Any numbers that you see from under the car can't be a guarantee that the master is that size!
Scott Carlberg |
Dec 6 2003, 04:27 PM
Porsche MOTORSPORTS Group: Members Posts: 1,595 Joined: 17-April 03 From: Modesto, Ca Member No.: 580 |
Ladies & Gentlemen....
High Performance House's own Rich Bontempi. I know, I can read, he joined back in February, but he's only had 12 posts, and this is the first time I've seen his name. Welcome Rich, er, Mr Bontempi (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) 914 guru Multiple time racing champion (IMG:style_emoticons/default/smilie_flagge24.gif) (IMG:style_emoticons/default/smilie_flagge24.gif) (IMG:style_emoticons/default/smilie_flagge24.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 01:05 PM |
