Keeping spare parts, it isn't a spare if it isn't usable!!!! |
Pat Garvey |
Apr 13 2007, 07:56 PM
Relay panels - does this have value? I just found it from over 20 years ago. Can it be helped/fixed? How?
I've heard that some have recoated the based, to keep oxidation from taking over. With what? How? THX Pat Attached image(s) |
John |
Apr 13 2007, 08:04 PM
As long as there is continuity through all the connectors, it is a working unit. The black material (potting compound??) typically cracks and falls out as part of yours has done.
When that happens, some of the connectors can move when you plug them in such as the voltage regulator. I have heard of people chipping all that hardened black material out and using something else to seal it up. Pretty much anything non-conductive that you can fill it with will help support the copper tracks that make up the circuit board and protect it from moisture. You could mix up a bunch of epoxy and pour that in to seal it up. I've got a bunch of those in boxes. I don't use them with my 6-conversions. |
skline |
Apr 13 2007, 08:06 PM
Just use a non conductive resin with hardener and it should be fine.
Pat Garvey |
Apr 13 2007, 08:11 PM
Just use a non conductive resin with hardener and it should be fine. Umm, these parts are irreplaceable, so what are you suggesting as "non-conductive" resin? BTW - I'm only asking - no slam! This is my only spare, should I carefully chip out the old crap? Replace it with....? Thanks Pat |
John |
Apr 13 2007, 09:53 PM
You could try some kind of Fiberglass resin. You could try a waterproof BONDO type of catalyzed resin, or like I suggested, Epoxy works.
I believe there is some kind of electrical potting material that is used in explosion proof fittings. You would have to check with an electrical supply house for details. |
Aaron Cox |
Apr 13 2007, 10:28 PM
rick 918-S |
Apr 14 2007, 07:54 AM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Windshield urothane. You can get it in large calk gun sized tubes.
Lo-Fi Version | Time is now: 28th May 2024 - 05:28 AM |
