Swaybar backing plate, How thick? |
marks914 |
Apr 14 2007, 06:45 AM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
While I have my tank out to do my new heater i was going to install my swaybar. Its a 19mm bar but it does not have the backing plates for the inside. I was planning on fabbing a piece and welding some nuts on the back. How thick should this plate be?
Thanks Mark |
davep |
Apr 14 2007, 06:50 AM
914 Historian Group: Benefactors Posts: 5,151 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The front swaybar mount, factory part, is probably normal body thickness 0.8mm or .032". I think about double that would be better. If you have to have an exact measurement I might be able to measure my part.
rick 918-S |
Apr 14 2007, 07:59 AM
Hey nice rack! -Celette Group: Members Posts: 20,470 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Mark, I'd use 14-16 GA.
although there are many threads on sway bars here's a recent one. http://www.914world.com/bbs2/index.php?sho...c=60071&hl= |
skline |
Apr 14 2007, 08:57 AM
Why wouldn't you just order one from Engman? They are perfect for what you want to do. I have bought them for every car I have done and he is fast at shipping too. Here is a link to his stuff. I think I have bought everything he makes and used it on my car with no complaints, ever.
http://www.914world.com/bbs2/index.php?showtopic=60168 |
Bartlett 914 |
Apr 14 2007, 09:20 AM
The original is 20 gage. It is welded on the outside. I made mine from 16 gage. I made a tool to form the flange on the through hole. I made threaded bosses and welded them in place.
marks914 |
Apr 14 2007, 09:33 AM
Why wouldn't you just order one from Engman? They are perfect for what you want to do. I have bought them for every car I have done and he is fast at shipping too. Here is a link to his stuff. I think I have bought everything he makes and used it on my car with no complaints, ever. http://www.914world.com/bbs2/index.php?showtopic=60168 I can water jet one in about 15 minutes for free and I was going to put the bar in today. Plus I just like making stuff. Mark |
skline |
Apr 14 2007, 09:40 AM
Why wouldn't you just order one from Engman? They are perfect for what you want to do. I have bought them for every car I have done and he is fast at shipping too. Here is a link to his stuff. I think I have bought everything he makes and used it on my car with no complaints, ever. http://www.914world.com/bbs2/index.php?showtopic=60168 I can water jet one in about 15 minutes for free and I was going to put the bar in today. Plus I just like making stuff. Mark O I C I am just lazy and would rather have someone else do it for me (IMG:style_emoticons/default/smile.gif) How is my guage coming along? I cant afford it just yet but I will be getting one of them from you this year for my car. |
Bartlett 914 |
Apr 14 2007, 09:57 AM
QUOTE I can water jet one in about 15 minutes for free and I was going to put the bar in today. Plus I just like making stuff. Mark Want a drawing? I have a .DWG and maybe I can give you a .DXF |
marks914 |
Apr 14 2007, 09:59 AM
Why wouldn't you just order one from Engman? They are perfect for what you want to do. I have bought them for every car I have done and he is fast at shipping too. Here is a link to his stuff. I think I have bought everything he makes and used it on my car with no complaints, ever. http://www.914world.com/bbs2/index.php?showtopic=60168 I can water jet one in about 15 minutes for free and I was going to put the bar in today. Plus I just like making stuff. Mark O I C I am just lazy and would rather have someone else do it for me (IMG:style_emoticons/default/smile.gif) How is my guage coming along? I cant afford it just yet but I will be getting one of them from you this year for my car. The gauge is ready any time. I am also working on a modern "guts" V8/6cyl tach as well as the heater setup and the Porschev SBC valve covers. I should be able to test the heater as soon as I get the swaybar and the tank in. Mark |
RustyWa |
Apr 14 2007, 05:41 PM
Working Member Group: Members Posts: 610 Joined: 2-January 03 From: Kent, WA Member No.: 72 |
The original is 20 gage. It is welded on the outside. I made mine from 16 gage. I made a tool to form the flange on the through hole. I made threaded bosses and welded them in place. Those are nice! Do you still need to make that little notch on the tank side with you system? |
Bartlett 914 |
Apr 14 2007, 05:47 PM
The original is 20 gage. It is welded on the outside. I made mine from 16 gage. I made a tool to form the flange on the through hole. I made threaded bosses and welded them in place. Those are nice! Do you still need to make that little notch on the tank side with you system? No! I have the car stripped but I think these can be installed with the tank in place. I use a template and center punch 4 spots. The large one is 1.25" (IIRC). I used a hole saw. The other 3 are drilled using a step drill. I welded it in place through several small holes and some welds on the outside. It is nearly exactly how Porsche did it only theirs was pretty and 20 gage instead of 16. |
RustyWa |
Apr 14 2007, 05:49 PM
I think you did a nice job!
Bartlett 914 |
Apr 14 2007, 05:51 PM
rick 918-S |
Apr 14 2007, 06:22 PM
I think you did a nice job! Yep, (IMG:style_emoticons/default/agree.gif) I saw them installed on Marks car. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 PM |
