2 Pages V < 1 2
> Yet another 911 strut thread, Confustion about KONI inserts in KONI struts
veltror
post Feb 10 2009, 06:16 PM
Post #21
I wish I was still living in the US, all this would be far cheaper as it is I am living back here where well it isn't. Does not look like I am going to make the 40th anniv but thena agin. I have also sent you a PM so I can spend lots of money... The pound is at a three week high WoooHoooo (IMG:style_emoticons/default/rolleyes.gif)
Roman
Eric_Shea
post Feb 10 2009, 06:23 PM
Post #22
PMB Performance
Joking... I meant "I'm rather taken aback that you're not going to give those to me!" (IMG:style_emoticons/default/biggrin.gif)
Spend all you want! We'll make more. Thanks for doing your part to stimulate me the US economy!! (Now, if I can just find a bank to give me a 3 year balloon and about $500k over my valuation in an equity loan. Hookers and whiskey for all my friends!) (IMG:style_emoticons/default/w00t.gif)
Richard Casto
post Feb 11 2009, 07:29 AM
Post #23
Blue Sky Motorsports, LLC
QUOTE(Eric_Shea @ Feb 10 2009, 07:13 PM) *
You're going Koni to Koni so your pitch on those struts will be the same. Why would you need a new nut?
I think the vast majority of the replacements struts sold are for Boge struts since those are the most common type. So I believe that when Koni packages up the inserts, they include a centering ring and nut that works with the Boge strut (or maybe you re-use the Boge nut, I am not sure). Regardless, if you are going to use the OEM Koni strut, then you need the special gland nut because the Koni strut nut is different than the Boge strut nut (different thread, etc.) You also can't reuse the nut that is on the OEM strut as it has the right threads but otherwise the wrong shape to hold the newer insert into place. The Koni application PDF list the gland nut and I think Roman has the right number in his earlier post.
So in short, there is slightly more work/parts needed to put a Koni insert into a Koni strut. (IMG:style_emoticons/default/smile.gif)
ericread
post Feb 11 2009, 11:00 AM
Post #24
The Viper Blue 914
Eric Shea;
Aren't you out of the business now? Rumor has it you no longer are around?
(IMG:style_emoticons/default/chairfall.gif)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 9th June 2026 - 12:11 PM
