Power Bleeder |
Power Bleeder |
Colorado_Doug |
Apr 22 2007, 12:44 PM
Newbie Group: Members Posts: 8 Joined: 14-March 04 From: Evergreen, CO Member No.: 1,793 |
Hi, I've just bought a Motive Products pressure bleeder. I want to get my brakes bled so I can get back on the road. I was wondering what pressure range should I use? It has a 0-30 PSI gauge on it.
Thanks, Doug |
jasons |
Apr 22 2007, 12:53 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I *think* you pump it up around 15. But, thats from memory of the last time I used mine, about 2 years ago.
skline |
Apr 22 2007, 02:16 PM
Yes, I have one too, they are great for most cars. 8 to 12 pounds is all you need, any more than that you wind up blowing past the seals at the M/C
JPB |
Apr 22 2007, 02:26 PM
GeorgeRud |
Apr 22 2007, 09:28 PM
Add a set of speedbleeders with the one way valves and you have the easiest way to bleed the brakes by yourself! Just be sure to watch the level of fluid in the master cylinder, you can go through brake fluid very quickly!
I made my own pressure bleeder by drilling a hole in the top of a spare master cylinder cap and installing a tire valve stem. I use a clip on air chuck and clamp off the overflow hose off the master cylinder, and 15 psi will work fine. |
SGB |
Apr 22 2007, 09:30 PM
I got the power bleeder with speedbleders too, but I have to get it up to about 20 psi to get flow.
jdogg |
Apr 22 2007, 10:34 PM
Member Group: Members Posts: 431 Joined: 28-January 03 From: Youngsville, NC Member No.: 204 |
10 PSI has always worked for me....
DBCooper |
Apr 23 2007, 06:45 AM
Put some pressure in and see how much you need. 10 lbs has always been enough for me, too.
Lo-Fi Version | Time is now: 17th May 2024 - 11:13 PM |
