Santa Rosa Zone & AX events #2 & #3 |
grantsfo |
Apr 23 2007, 11:24 PM
Arrrrhhhh! Group: Members Posts: 4,327 Joined: 16-March 03 Member No.: 433 Region Association: None |
Anyone going? Should be fun! I'm fairly sure we have at least 5 914's going.
http://zone7.pca.org/index.php?page=event&...mp;event=2007a3 This post has been edited by grantsfo: Apr 23 2007, 11:27 PM |
DanT |
Apr 30 2007, 04:41 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
alignment means alot to your total handling...
what shocks do you have? with stock front Torsion bars and 140# rear springs I would be disconnecting the rear bar completely... what you have is basically an old class AI set up. I ran that in a 1.7 for several years. stock front torsion bars, 140# rear springs 19mm Weltmeister front sway bar no rear sway bar koni adjustables front and rear -2 degrees camber front and -3 degrees rear. very neutral handling and use the front sway bar and konis to adjust understeer and oversteer. I was running old school DOT Rs yoko A008Rs |
Lo-Fi Version | Time is now: 20th May 2024 - 09:22 AM |
