ok, it wont start everythings hooked up, advice... |
skline |
Dec 6 2003, 12:44 AM
Jared,
If I do not hear from Kevin about tomorrows run up to Willow Springs, I will be free in the morning for a few hours. I am not sure where you are at though. I use a rotary pump on mine. I had the Facet pump on there before and it was mounted in the rear of the car by the battery. The rotary pump I just bought, I mounted it up front where the factory FI pump was mounted. The rotary pump is much better than the Facet, I replaced mine because it leaked when I hooked it back up to fire up the new 2270. I figured everything else was new, I should replace it as well. The Facet pumps do click and the rotary are nice and quiet. More efficient too. $50.00 as opposed to 35.00. PM me with your address and I will let you know in the morning. Around 8 or so. |
Lo-Fi Version | Time is now: 4th June 2024 - 11:54 AM |
