The engine keeps running after I turn off the key |
chris914 |
Apr 29 2007, 10:34 PM
Member Group: Members Posts: 489 Joined: 24-July 04 From: San Diego, CA Member No.: 2,393 Region Association: Southern California |
My engine keeps running after I turn it off.
My Pertronic ignition died after hooking up the adapter for the tachometer. It was working for a while. But as I was tuning the carburetors the engine stopped running and wouldn’t start again. I disconnected the MSD and the engine still wouldn’t start. I put the points in and the engine started. Then I hooked the MSD and the engine started again. But when I turn off the key the engine keeps running Has anyone had this problem before? The power to the points/MSD is an original wire from the engine relay board. Should I run a separate wire from the ignition key? |
Apr 29 2007, 10:44 PM
Resident German Group: Admin Posts: 41,648 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Should I run a separate wire from the ignition key? only if you like burning your car to the ground ... i suspect the ignition switch. you'll fry your pertronix if you leave the key in the "ON" position. sounds like you got a faulty switch that is stuck in "ON" which would explain why the engine keeps running and why the pertronix fried ... got another switch you can try? (IMG:style_emoticons/default/cool_shades.gif) Andy |
Gint |
Apr 30 2007, 07:21 AM
Mike Ginter Group: Admin Posts: 16,075 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
My car was doing that when I had the timing at idle very retarded. Since you were changing stuff out it's a possibility.
iamchappy |
Apr 30 2007, 07:26 AM
Power is leaking back into the system is keeping the MSD energized, a one way diode spliced into the the blue alternator wire either before the regulator or the wire running to the alternator light in the dash should solve it.
Aaron Cox |
Apr 30 2007, 05:38 PM
Power is leaking back into the system is keeping the MSD energized, a one way diode spliced into the the blue alternator wire either before the regulator or the wire running to the alternator light in the dash should solve it. (IMG:style_emoticons/default/agree.gif) BING BING BING... we have a winner! |
McMark |
Apr 30 2007, 06:20 PM
(IMG:style_emoticons/default/agree.gif) with Aaron.
ejm |
Apr 30 2007, 06:38 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,692 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
Common problem... check the MSD troubleshooting info
Lo-Fi Version | Time is now: 19th May 2024 - 01:40 PM |
