Fan hub removal problem, I can't get it off...help |
whitey |
May 4 2007, 11:10 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I need to pull my fan hub (the part behind the fan with 3 bolts) to install a new seal. I used a puller but it doesn't want to come off. My flywheel is removed and it seems to pull the crank forward but won't release. Should I heat the hub or what? Is this part normally this hard to remove?
Thanks for the help, Dave |
Lo-Fi Version | Time is now: 18th May 2024 - 10:48 PM |
