Fan Housing Crack, Any way to repair |
whitey |
May 5 2007, 09:11 AM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
The lower area of my housing has an inch crack developing...is there any way of repairing this?
Thanks, Dave |
mills914/s |
May 5 2007, 09:26 AM
Member Group: Members Posts: 253 Joined: 23-December 06 From: Coeur D'Alene... IDAHO Member No.: 7,363 Region Association: Northern California |
Find out why it cracked then clean it and JB weld it ..Thats what Id do. But others may say different
Katmanken |
May 5 2007, 09:33 AM
The housings sometimes have small lines of flash from the molding process, which if dirty, can look like a crack.
Wouldn't worry much if it is the housing. It's not a structural member and only guides air. The fan is a different story. One thing you can do is to drill a small hole at each end of the crack. That''s an old aircraft trick to stop the crack from propagating. The crack probably is a little longer than you think so drill accordingy. Plug the holes with epoxy and you are good to go. Ken |
Lo-Fi Version | Time is now: 19th May 2024 - 01:32 AM |
