whitey
May 5 2007, 09:11 AM
The lower area of my housing has an inch crack developing...is there any way of repairing this?
Thanks, Dave
mills914/s
May 5 2007, 09:26 AM
Find out why it cracked then clean it and JB weld it ..Thats what Id do. But others may say different
Katmanken
May 5 2007, 09:33 AM
The housings sometimes have small lines of flash from the molding process, which if dirty, can look like a crack.
Wouldn't worry much if it is the housing. It's not a structural member and only guides air. The fan is a different story.
One thing you can do is to drill a small hole at each end of the crack. That''s an old aircraft trick to stop the crack from propagating. The crack probably is a little longer than you think so drill accordingy. Plug the holes with epoxy and you are good to go.
Ken
