Tranny Oil leak., Will it screw up my clutch? |
Borderline |
May 5 2007, 09:43 AM
Senior Member Group: Members Posts: 720 Joined: 8-February 05 From: San Juan Bautista, CA Member No.: 3,577 Region Association: Northern California |
After working all winter on the car I've finally got it running. I've put new seals on the axle shafts and replaced the o-ring on the speedo cable and now the trans has developed a new leak that appears to be coming from the input shaft. My question is: will the oil coming out of the input shaft seal make its way to the clutch and cause problems? It's a fair sized leak...leaves a little puddle on the garage floor.
I just don't have the mindset to deal with this now. I want to drive the fuchin thing. The work-time to drive-time ratio is way to high and the fun factor too low. How hard is it to replace the input shaft seal? Thanks. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 27th May 2024 - 08:54 AM |
