Borderline
May 5 2007, 09:43 AM
After working all winter on the car I've finally got it running. I've put new seals on the axle shafts and replaced the o-ring on the speedo cable and now the trans has developed a new leak that appears to be coming from the input shaft. My question is: will the oil coming out of the input shaft seal make its way to the clutch and cause problems? It's a fair sized leak...leaves a little puddle on the garage floor.
I just don't have the mindset to deal with this now. I want to drive the fuchin thing. The work-time to drive-time ratio is way to high and the fun factor too low.
How hard is it to replace the input shaft seal?
Thanks.
dr914@autoatlanta.com
May 5 2007, 11:10 AM
QUOTE(Borderline @ May 5 2007, 08:43 AM)
Thanks.
bottom line, yes it will. Easy to replace, just remove the transmission
Martin Baker
May 5 2007, 11:42 AM
I had the same thing happen to me after a clutch install, the seal appeared fine, and mine did not leave a puddle, just seeping and it took it about a month, then it started slipping on spirited up hill climbs under power, so I took it apart to find that this seal had failed. I had heard of this issue before, but did not think it would happen. I would also look closely at your disc. Make sure it didn't get gear lube saturated in the friction surface. If so, toss it, and replace. Piece of mind is a wonderfull thing. I think the seal is like $3.00 dollars, and I will never do another clutch without changing this seal.
Borderline
May 5 2007, 09:27 PM
That's not the answer I was looking for
...Time to drop the engine ....again.
Thanks guys!
Dr Evil
May 5 2007, 09:31 PM
You dont have to drop the engine to remove the tranny. I can take a tranny off and on in 1hr or less leving th engine in the car. You can do it. Changing the seal is not too hard. We can help.
Tobra
May 6 2007, 09:41 AM
If I got gear oil in there and was going to take it apart, I would replace the friction surface anyway, clutch discs aren't that much are they?
I would also at the very least have a machinist who knows his businss check out the flywheel. Seems to me if it slipping noticeably, it is probably gettin hot.
