can someone point me to.. |
biosurfer1 |
May 6 2007, 12:03 PM
Teener fo Life! Group: Members Posts: 3,020 Joined: 3-August 03 From: Roseville, CA Member No.: 977 Region Association: Northern California |
the pelican article on how to adjust my shifter? I cant seem to find it on thier website or I'm just not looking in the right spot.
I have tried the hayes manual way with no success....some parts of my linkage just dont look right but I thought I'd try one more time. |
So.Cal.914 |
May 6 2007, 12:41 PM
biosurfer1 |
May 6 2007, 01:27 PM
thanks socal...i've been there, but I cant find the write up on that page.
I thought there was a step by step of how to adjust it...I'll keep looking |
So.Cal.914 |
May 6 2007, 04:41 PM
Ok which car is it, the 72 or 74, tail shift or side shift?
Whats the problem? Whats it doing? Or not doing? |
biosurfer1 |
May 6 2007, 05:51 PM
its a side shift.
its not doing anything correctly:) when I try to adjust it using the haynes way, it seems like its going well but when i tighten the shifter to the rod, its hard to find any gears and the ones I do are hard to put into gear, not even close to working. |
Tobra |
May 8 2007, 02:32 PM
Senior Member Group: Members Posts: 1,453 Joined: 22-August 05 From: Sacramento, CA Member No.: 4,634 |
Brett, when you install it, if the shifter rod is pushed too far forward, or not far enough it will throw you off. At the part in the car where the little clampy thing grabs it.
Got my head almost above water so should be able to drive over and we can look at mine, look at yours and figure it out. Hope the new job is working out well. |
KaptKaos |
May 9 2007, 12:44 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Here is how I did mine (1):
Loosen the big bolt at the base of the shifter that tightens to the shift rod. The shifter should move easily on the rod. Go to the back of the car and put the tranny into second gear (mid way up/down with the ball cup being pushed towards the rear of the car). Go back into the car and gently position the shifter to about where you would expect second gear to be. Tighten down the bolt at the base of the shifter. Get someone that can see the three up/down levels of the shifter in back and run through the gears. Have them tell you where the selector is. This way you can see if you can get into all of your gears. Wash/Rinse/Repeat until you get it where you want it. Remember that the splines on the shift rod can really impact R1 and 45 so take your time if you decide to rotate the rod. Good luck. (1) Method a translation from Aaron Cox over a cell phone about a year and a half ago when I did my bushings. YMMV (IMG:style_emoticons/default/biggrin.gif) |
rigglet |
May 9 2007, 09:44 AM
Member Group: Members Posts: 149 Joined: 28-November 06 From: Westfield, Indiana Member No.: 7,272 Region Association: Upper MidWest |
Here is how I did mine (1): Loosen the big bolt at the base of the shifter that tightens to the shift rod. The shifter should move easily on the rod. Go to the back of the car and put the tranny into second gear (mid way up/down with the ball cup being pushed towards the rear of the car). Go back into the car and gently position the shifter to about where you would expect second gear to be. Tighten down the bolt at the base of the shifter. Get someone that can see the three up/down levels of the shifter in back and run through the gears. Have them tell you where the selector is. This way you can see if you can get into all of your gears. Wash/Rinse/Repeat until you get it where you want it. Remember that the splines on the shift rod can really impact R1 and 45 so take your time if you decide to rotate the rod. Good luck. (1) Method a translation from Aaron Cox over a cell phone about a year and a half ago when I did my bushings. YMMV (IMG:style_emoticons/default/biggrin.gif) Not trying to hijack this thread, but does anyone have some similar instructions for adjusting/fine tuning a tail shift? |
Aaron Cox |
May 9 2007, 12:30 PM
Here is how I did mine (1): Loosen the big bolt at the base of the shifter that tightens to the shift rod. The shifter should move easily on the rod. Go to the back of the car and put the tranny into second gear (mid way up/down with the ball cup being pushed towards the rear of the car). Go back into the car and gently position the shifter to about where you would expect second gear to be. Tighten down the bolt at the base of the shifter. Get someone that can see the three up/down levels of the shifter in back and run through the gears. Have them tell you where the selector is. This way you can see if you can get into all of your gears. Wash/Rinse/Repeat until you get it where you want it. Remember that the splines on the shift rod can really impact R1 and 45 so take your time if you decide to rotate the rod. Good luck. (1) Method a translation from Aaron Cox over a cell phone about a year and a half ago when I did my bushings. YMMV (IMG:style_emoticons/default/biggrin.gif) hahah... and make sure your cone screws are tight FIRST. too funny.... tech support mobile LOL |
eg914 |
May 10 2007, 12:50 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
Brett,
The information you seek is well hidden. The Pelican article titled "914 Shifting Improvements", in the section titled "Shifter Lever" has adjustment instructions. It is a little over half way through the article, and in the second paragraph of the Shifter Lever section. See ya |
Lo-Fi Version | Time is now: 9th May 2024 - 02:08 AM |
