Anyone installed a Corbeau Forza?, going to install one need help |
DrifterJay |
Dec 5 2003, 09:58 PM
I break stuff... Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None |
yeah...im sick of working under the car...still not running, havent got under there since posting about the fuel pump...will do it tomorrow. Thought I would do something different tonight...well I have a Corbeau Forza, the instructions are pretty much useless, and there is no info in the Haynes manual. How do you switch it? What hardware is needed from original rails? Just wanted to ask before I fu^k something up. Thanx
ps: I do have the adapters for the rails. Anyone have any photos of this also? (IMG:style_emoticons/default/icon14.gif) |
DrifterJay |
Dec 5 2003, 10:12 PM
anyone?
sj914 |
Dec 5 2003, 10:28 PM
Well first you need to take the seat off the car. just adjust it forward as far as it will go and then there will be a total of four bolts at the back of the seat mounting rails, two on each side.
After you get the seat out look under the seat rail that has the tilt handle on it and you should see a release, thats what will let you slide the seat off of the rail. Once you get the seat separated from the slider mount, all thats left is the rails that are directly screwed onto the seats themselves. As far as mounting the new seat there are kits that allows you to either mount the seat directly on to the floorboard or to your existing slider. |
DrifterJay |
Dec 5 2003, 10:29 PM
im lazy...did a quick search
DrifterJay |
Dec 5 2003, 10:31 PM
thank you..im as far as having the seat out..need to take off the back pad...thats a new adventure...have to figure out how to remove the engine lid release dealio. Dont want to tear pad....is perfect...the only thing not jacked up on my car...lol
sj914 |
Dec 5 2003, 10:35 PM
The engine lid release just screws out and then the bezel screws out as well.
Steve |
Dec 5 2003, 10:39 PM
914 Guru Group: Members Posts: 5,585 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Here's a link to the pelican site that has complete instructions.
I installed a pair in my 914. Drilling is required because the holes don't line up. http://www.pelicanparts.com/techarticles/9...at_install3.htm Steve |
DrifterJay |
Dec 6 2003, 05:35 AM
its in...and its purty (IMG:style_emoticons/default/wub.gif)
I think I am gonna go for a drive (IMG:style_emoticons/default/driving.gif) if only it would start... (IMG:style_emoticons/default/laugh.gif) J |
Lo-Fi Version | Time is now: 15th May 2024 - 12:27 PM |
