Anyone priced out a fuel pump lately? |
CHAFF |
May 9 2007, 01:59 AM
Member Group: Members Posts: 167 Joined: 13-September 04 From: Regina, SK Member No.: 2,749 |
Hey eveyone...
Has anyone found a good price on a fuel pump lately? I'm in the market for a new one since I've recently had to switch to my spare. -L |
drgchapman |
May 9 2007, 08:48 AM
Current Stable Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest |
~$400.00.........
Marlow |
May 9 2007, 10:38 AM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
The Bosch's run about $240 to $400, depends on whether you need the 2-port or 3-port (the 2-port can be substituted for the 3-port with a little extra work).
If you're not opposed to aftermarket options check out Mallory, Walbro (GSL-393), or other inline pumps. As long as they can output at least 35 to 40 psi they should work fine. I use the Walbro and it cost about $130, works great. Will require a little extra work to get installed but nothing major. The Mallory looks suspiciously like the Walbro and is a bit more expensive, like $200. |
IronHillRestorations |
May 9 2007, 02:05 PM
I. I. R. C. Group: Members Posts: 6,717 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
I've tried a couple Walbros on cars with carbs, and they worked OK but died way to soon and out of warranty.
My .02 is to spend the extra for the Bosch and it will last a long time. |
toon1 |
May 9 2007, 02:14 PM
Senior Member Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 |
I just put in an MSD pump, cost, $95, avail at Summit. It's a bit noisy but it's a durable pump.
dr914@autoatlanta.com |
May 9 2007, 02:16 PM
914 Guru Group: Members Posts: 7,844 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
those rebuilt bosch fuel injection pumps for the 70-74 914-4s are usually about 145-165 $$
Jenny |
May 9 2007, 05:43 PM
Advanced Member Group: Members Posts: 4,060 Joined: 6-January 03 Member No.: 96 Region Association: None |
I got mine for $170 at High Performace House. I think there's a core charge too, dunno what that is because I gave mine back.
Jen |
Katmanken |
May 9 2007, 08:09 PM
I just put an inline Pierburg in my Vanagon for less than the Bosch- supposedly used by the VW factory in their Vanagons. Mine is a 2.1L wasserboxer with the Digifant version of the Ljet so it's a match for a teener in volume, pressure and a remarkably similar system.
Go here Bus depot They have Bosch pumps on sale now for $159 and it looks like a match for the type 4 Bus engines Hmm Pierburg used to be cheaper than Bosch. Ken |
CHAFF |
May 9 2007, 09:31 PM
Hi Ken is this a 3 port pump?
http://www.busdepot.com/details.jsp?partnumber=GFP301 I just put an inline Pierburg in my Vanagon for less than the Bosch- supposedly used by the VW factory in their Vanagons. Mine is a 2.1L wasserboxer with the Digifant version of the Ljet so it's a match for a teener in volume, pressure and a remarkably similar system. Go here Bus depot They have Bosch pumps on sale now for $159 and it looks like a match for the type 4 Bus engines Hmm Pierburg used to be cheaper than Bosch. Ken |
Lo-Fi Version | Time is now: 10th May 2024 - 03:20 PM |
