Found some melted wires in the loom, What are they and where do they go??? |
JBart |
May 9 2007, 08:47 PM
UNDER CONSTRUTION Group: Members Posts: 110 Joined: 9-October 06 From: Wildomar Ca. Member No.: 7,019 |
Ok the day started out good I decided to clean out the engine compartment while I Have the engine out I got almost all the grease out and decide to shake the wire loom to get the water out from the presure washer. I then take the plastic loom off of the wire to find wires melted together. The wire which melted itself to all the other wires is grey. there is a picture below and then I found another wire which was not hooked up to anything it's BLK/red coming off pin # 13 out of the relay board. Is that the wire which should be running my fuel pump? By the way I'm running carbs so if I remember I need to grd. one of the other pins to make this wire HOT . Is that correct?
Sorry for jumping all over the place I found way to many lil' prob. today. Thanks, jbart Attached image(s) |
bondo |
May 9 2007, 09:10 PM
Not sure about which wire is which, but that plastic split loom stuff is NOT stock. Someone has been in there messing around, which may very well be the cause of the meltdown.
JBart |
May 9 2007, 09:17 PM
I'm just worried that the wire which melted is melted further through the car. Like I said though I took a ohm meter from the melted wire to the fuse panel and it rang at the 7th fuse from the left but did not ring to ground or to any other fuse . Now I Hope and Pray (IMG:style_emoticons/default/headbang.gif)
May 9 2007, 10:04 PM
914 Idiot Group: Members Posts: 14,984 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
What are the colors of the wires that melted? I can't make them out very well from the pic... I believe the grey wire powers the license plate light, at least on a 74. What year is your car?
--DD |
May 9 2007, 10:16 PM
Found some melted wires in the loom, What are they and where do they go??? you got a haynes manual? it's got a wiring diagram ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
JBart |
May 9 2007, 10:35 PM
Dave,
The car is a 72' and the wire is solid grey. The other wires look fine it looks like the grey wire just stuck to the other wires. The other wire i'm trying to figure out is this blk/with red stripe which come off pin #13 from the relay board. It's the wire with the zip tie on it. Thanks, jbart Attached image(s) |
McMark |
May 9 2007, 11:11 PM
Looks like fuel pump to me.
JBart |
May 9 2007, 11:21 PM
Thank you ,
If you don't mind me asking where did you get the colored wiring dia? I do have a Haynes but it's hard to read the wire colors (or I'm getting old). Thanks, jason |
McMark |
May 10 2007, 12:36 AM
Here:
Attached thumbnail(s) |
JBart |
May 10 2007, 11:52 PM
Thank You McMark,
I hate to be a PITA but would you be willing to tell me where you purchaced thoughs Dia. after saving them to my comp. if I zoom in they go blury. Thanks, jbart |
McMark |
May 11 2007, 12:22 AM
I found the images on the net somewhere 4 or 5 years ago. (IMG:style_emoticons/default/confused24.gif)
Click on the picture to see the full size version, then save the image. You're saving the smaller thumbnail version. |
JBart |
May 11 2007, 01:36 AM
JeffBowlsby |
May 11 2007, 08:29 AM
914 Wiring Harnesses Group: Members Posts: 8,503 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Black/red could be a coil wire...
May 11 2007, 01:09 PM
I hate to be a PITA but would you be willing to tell me where you purchaced thoughs Dia. after saving them to my comp. if I zoom in they go blury. i got color copies that i bought a couple of years ago for a few bucks. the color diagram is out of the factory shop manuals, so if you can find someone who has a set of those, go and get some color copies ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
JBart |
May 14 2007, 10:08 PM
Thanks Sir Andy,
I'll keep my eyes open for a manual. But I think I found the sorce of my melt down. It looks like the wires going to the trunk light got pinched somewhere or somehow about 8" from the trunk light . The wire was melted almost to the firewall but why wouldn't the fuse blow ????? Thanks, jbart |
May 14 2007, 10:33 PM
The wire was melted almost to the firewall but why wouldn't the fuse blow ????? because the PO used a fuse with the incorrect amps? (IMG:style_emoticons/default/confused24.gif) Andy |
Lo-Fi Version | Time is now: 14th May 2024 - 01:33 AM |
