Car won't turn off, Oh brother |
marks914 |
May 11 2007, 08:40 PM
Senior Member Group: Members Posts: 845 Joined: 9-October 04 From: the motor city Member No.: 2,912 Region Association: None |
I had a problemt oday. I was driving down the road on this lovley 70 degree day when I went around a corner and found that some wires that I had run somehow got wrapped around the steering column. A few wires were pulled off of their male connectors on the fuse block, no wires were damaged, just pulled off the connection. So I get everything back together, start the car and now it won't turn off. WTF?
I always have current going to the coil + lead unless I unplug the black wire(s) from the #9 fuse. I can't seem to find the problem. Oh yeah, my gauges are out too. Does anyone have a good pic or diagram of a 72 fuse box? Its not the ignition switch, it new and was working fine, I umplugged it and had the same result. I am running a GM HEI. All was well until that corner. Or any suggestions Mark |
jonferns |
May 11 2007, 08:43 PM
hey! i have a 74...if you want I can take a quick run outside and take a pic....--JON
tracks914 |
May 11 2007, 10:19 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Sorry but that's funny (IMG:style_emoticons/default/av-943.gif)
I don't mean to laugh but (IMG:style_emoticons/default/happy11.gif) OK yes I do. That's funny. (IMG:style_emoticons/default/av-943.gif) Dump the clutch and go have a beer. (IMG:style_emoticons/default/beerchug.gif) |
John |
May 11 2007, 10:30 PM
You must have an un-switched hot wire (red) landed on the fuse block in the wrong bank of fuses (the black wires are switched hots including the wire for the coil). If you look carefully, there are a couple of groups of fuses tied together. Some are switched hot and some are constant hot.
Recheck the positions that you landed the wires on the fuse block. Since you can kill the coil by pulling fuse #9, then start there. There is a "always hot" wire landed to the other side of the fuse (it's probably in a group). |
Lo-Fi Version | Time is now: 10th May 2024 - 04:00 AM |
