fog light voltage |
fog light voltage |
ruddyboys |
May 13 2007, 07:21 AM
Hummel eigentümer Group: Members Posts: 594 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Figured my old fog light bulbs were out, but checked the voltage anyway, I was getting about 7 volts??? should it be 12.
smontanaro |
May 13 2007, 07:25 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Ummm... yeah. Unless you were measuring on a 356 that hadn't been converted to 12 volts yet...
Skip |
ruddyboys |
May 13 2007, 07:30 AM
OK Then were is my extra voltage going???
Spoke |
May 13 2007, 08:13 AM
Chances are that one or more connections are oxidized or dirty. Are you measuring voltage with the lamp removed or while lit? Could be a connector, the switch, or the base of the bulb. Sometimes removing connectors and re-inserting will clean a dirty connection. Use contact cleaner and sandpaper/small files where practical to clean contacts and connectors.
Spoke |
So.Cal.914 |
May 13 2007, 08:15 AM
Bad ground possably
Lo-Fi Version | Time is now: 9th May 2024 - 04:35 PM |
