ruddyboys
May 13 2007, 07:21 AM
Figured my old fog light bulbs were out, but checked the voltage anyway, I was getting about 7 volts??? should it be 12.
smontanaro
May 13 2007, 07:25 AM
Ummm... yeah. Unless you were measuring on a 356 that hadn't been converted to 12 volts yet...
Skip
ruddyboys
May 13 2007, 07:30 AM
OK Then were is my extra voltage going???
Spoke
May 13 2007, 08:13 AM
Chances are that one or more connections are oxidized or dirty. Are you measuring voltage with the lamp removed or while lit? Could be a connector, the switch, or the base of the bulb. Sometimes removing connectors and re-inserting will clean a dirty connection. Use contact cleaner and sandpaper/small files where practical to clean contacts and connectors.
Spoke
So.Cal.914
May 13 2007, 08:15 AM
Bad ground possably
