Martin Baker |
May 13 2007, 02:28 PM
I just heard I sold my cars! Group: Members Posts: 1,140 Joined: 11-February 03 Member No.: 290 Region Association: Northern California |
davep |
May 13 2007, 02:38 PM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
bleyseng, bowlsby, brad anders would be good guesses
sixnotfour |
May 13 2007, 04:18 PM
914 Wizard Group: Members Posts: 10,430 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
william harris |
May 13 2007, 10:01 PM
914 Restorer Group: Members Posts: 1,459 Joined: 9-January 04 From: Hamilton, MA Member No.: 1,539 |
Bleyseng/Geoff did mine and it make all the difference in the world.
Martin Baker |
May 13 2007, 11:23 PM
sixnotfour |
May 14 2007, 03:06 AM
Well then this looks like it is going to be pretty popular at the auction;
http://www.914world.com/bbs2/index.php?sho...c=71384&hl= |
bd1308 |
May 14 2007, 10:54 AM
the full load stop?
I think they put them in to decrease the chance for breakage. |
pbanders |
May 14 2007, 01:04 PM
Senior Member Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 |
the full load stop? I think they put them in to decrease the chance for breakage. True, for the most part. On most of the MPS's I've worked on, when you remove the full load stop, the injection duration at 0 inHg increases only by 0.1 or 0.2 ms, which says to me that it's mainly there to distribute the stress from the diaphragm. The extent of full-load enrichment is actually more of a function of the onset adjustment - early onset/greater extent - later onset/smaller extent. BTW, I don't do adjustments as a business - too many committments already! |
JeffBowlsby |
May 14 2007, 02:18 PM
914 Wiring Harnesses Group: Members Posts: 8,505 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
No not the full load stop. We are talking about a spacer ring at the perimeter of the diaphragm. Only found on the 2.0L MPSs. I wish I could find a photo...
Bleyseng |
May 14 2007, 04:16 PM
049 MPS's usually have the diaphram spacer ring and adjust to a 2.0L MPS settings fine.
Early 1.7 MPS Covers have a cast in ring/stop which makes it hard to adjust the WOT setting for a 2.0L. I usually swap in a 2.0L cover especially if its a late rebuild diaphram as they have a exterior press on clip. If you want me to set it up send it to me to evaluate the mps. (IMG:style_emoticons/default/thumb3d.gif) OH, on the WOT stop adjustment. If everything else is set up right the WOT can have a range of 11 to 1 to 16 to 1 depending of where its set. |
Martin Baker |
May 14 2007, 08:20 PM
This MPS used to be a 037 or 049 for the 2.0, the last of the numbers on the end case are ground out, like most of the re-conditioned ones I have seen. It now has this sticker on it which means nothing to me, probably only to however reconditioned it. Check out the photos to confirm. It holds great vacuum, I had it on my 74 2.0, and it ran OK, but gave me a high idle, and low power at WOT, I put the one I just bought from Otto, a 037 reconditioned one, and it runs great, great idle, and great power. I would like to know if it can be tuned to a 2.0 profile with minimal work, if not, I'll sell it. My Orange car is absolutely my last 4 cyl 914. I must not purchase any more 914 types.
Bleyseng |
May 14 2007, 11:38 PM
yeah, it should be able to be tuned (IMG:style_emoticons/default/thumb3d.gif)
Martin Baker |
May 15 2007, 04:37 PM
Do you have a web site, or should I PM you for details on how to get it to you?
Martin |
Lo-Fi Version | Time is now: 14th May 2024 - 08:37 PM |
