New Engine, Starting problems. |
StratPlayer |
May 13 2007, 05:41 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
New engine is in the car and friday was the first time trying to start the engine. This is a 2.0 EFI. Filled it with oil, built up some oil pressure, installed the plugs. Calibrated the new TS. Engine was hard to get started, when it started it ran like hell, was near the end of the day so bagged it until Sat. Sat. pulled a compression test and got these results, 1 = 125 lbs. 2 = 120 lbs. 3 = 120 lbs. 4 = 125lbs. Check the injectors and were flowing good. Checked all the connections from the harness, all looked good. MPS is new and has been tested and calibrated. ECU is rebuilt and match the MPS. AAR is working ok, decel valve seems to be working ok. All new hoses, vacuum hose all seem to be connected good with all new hose. Just looking for some advice on whats next for me to be looking for?
Lo-Fi Version | Time is now: 28th May 2024 - 09:11 PM |
