930 Turbo Suspension on Conversion Car |
brettmski |
May 14 2007, 02:21 PM
Newbie Group: Members Posts: 14 Joined: 2-March 05 From: Bellingham, WA Member No.: 3,704 |
I saw a set of 89 930 Turbo suspension (front and rear, everything including brakes) on ebay and it got me thinking. Has anyone ever put a Turbo suspension on a 914? I have a car to do a conversion on and maybe, just maybe I would look at doing the grand daddy suspension on it.
So.Cal.914 |
May 14 2007, 03:02 PM
From what I have heard 1989 was the last year that 911 suspension 'Bolted' right
on. I believe it will fit but you might ask Slits, Aaron Cox, Eric_Shea or one of the other Guru's. Try PMing one of them. (IMG:style_emoticons/default/smile.gif) |
Aaron Cox |
May 14 2007, 03:41 PM
up to 89 will bolt up. 930 front susp setups have bigger brakes, and more offset hubs.... (pushes your wheel outboard), which works if you have flares....
overkill for a narrow body car.... and only the brakes from the 930 rear can be adapted (and axles maybe), but they dont just bolt onto a 914 rear. still have to use a 914 rear arm |
skline |
May 14 2007, 07:18 PM
up to 89 will bolt up. 930 front susp setups have bigger brakes, and more offset hubs.... (pushes your wheel outboard), which works if you have flares.... overkill for a narrow body car.... and only the brakes from the 930 rear can be adapted (and axles maybe), but they dont just bolt onto a 914 rear. still have to use a 914 rear arm The wise Guru has spoken!! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/av-943.gif) |
PinetreePorsche |
May 14 2007, 09:56 PM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
up to 89 will bolt up. 930 front susp setups have bigger brakes, and more offset hubs.... (pushes your wheel outboard), which works if you have flares.... overkill for a narrow body car.... and only the brakes from the 930 rear can be adapted (and axles maybe), but they dont just bolt onto a 914 rear. still have to use a 914 rear arm I want to be sure I don't misunderstand: The pre-'89 bolts in AND doesn't require flares? And what rear change-over, aside from 5-hole, is worth spending money on? Which rear swap-out has bigger brakes AND still has some kind of parking brake compatible with the 914 cable set-up? |
echocanyons |
May 14 2007, 10:06 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
you can pretty much froget about the rear suspension, its a totally different setup.
the rear brakes may work. yep up to 89 911 struts are all good donors |
nein14 |
May 15 2007, 09:06 AM
Senior Member Group: Members Posts: 838 Joined: 6-February 03 From: USA Member No.: 262 |
I have 87' 930 Bilstein Struts on my car w/flares bolted up fine.
Aaron Cox |
May 15 2007, 09:23 AM
the turbo hubs have around 10 to 20mm extra width built onto them IIRC. which could mean flares if you try anything over a 7" wheel up front on a stock bodied car.
Lo-Fi Version | Time is now: 14th May 2024 - 05:43 PM |
