QUOTE(Aaron Cox @ May 14 2007, 02:41 PM)
up to 89 will bolt up. 930 front susp setups have bigger brakes, and more offset hubs.... (pushes your wheel outboard), which works if you have flares....
overkill for a narrow body car....
and only the brakes from the 930 rear can be adapted (and axles maybe), but they dont just bolt onto a 914 rear. still have to use a 914 rear arm
I want to be sure I don't misunderstand: The pre-'89 bolts in AND doesn't require flares? And what rear change-over, aside from 5-hole, is worth spending money on? Which rear swap-out has bigger brakes AND still has some kind of parking brake compatible with the 914 cable set-up?
