Finding TDC? |
Finding TDC? |
whitey |
May 14 2007, 02:49 PM
Member Group: Members Posts: 146 Joined: 8-February 07 From: Coto de Caza Member No.: 7,508 |
I've had my engine apart and need to find TDC for #1. I do not have my flywheel on. Which of the two fan marks is TDC and which is the timing mark? One is slightly larger.
Thanks for your help |
So.Cal.914 |
May 14 2007, 02:53 PM
When #1 piston is at the top and the valves are closed is TDC.
shaggy |
May 14 2007, 03:16 PM
mechanic/welder/fabricator Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None |
on a stock unmolested 1.7 and 2.0 fan there should be a large "0"
but then you need to make sure be pulling the driver side valve cover and making sure the #1 valves are closed. cylinder one is driver side towards flywheel. |
bd1308 |
May 14 2007, 03:19 PM
A chopstick works very well to tell when the piston is at TDC
Cap'n Krusty |
May 14 2007, 05:17 PM
The mark nearest the thick rib on the fan is the 28 degree BTDC mark, the other one (either a line or a "0") is the TDC mark. The Cap'n
Lo-Fi Version | Time is now: 14th May 2024 - 07:32 PM |
