whitey
May 14 2007, 02:49 PM
I've had my engine apart and need to find TDC for #1. I do not have my flywheel on. Which of the two fan marks is TDC and which is the timing mark? One is slightly larger.
Thanks for your help
So.Cal.914
May 14 2007, 02:53 PM
When #1 piston is at the top and the valves are closed is TDC.
shaggy
May 14 2007, 03:16 PM
on a stock unmolested 1.7 and 2.0 fan there should be a large "0"
but then you need to make sure be pulling the driver side valve cover and making sure the #1 valves are closed.
cylinder one is driver side towards flywheel.
bd1308
May 14 2007, 03:19 PM
A chopstick works very well to tell when the piston is at TDC
Cap'n Krusty
May 14 2007, 05:17 PM
The mark nearest the thick rib on the fan is the 28 degree BTDC mark, the other one (either a line or a "0") is the TDC mark. The Cap'n
