V8 Conversion, Possibilities |
Nor.Cal.914 |
May 15 2007, 10:52 AM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I'm looking into doing a V8 conversion this summer and I have some questions before I start. Does anyone know if there is an adapting kit for the 901 to bolt up to a Ford block? If so, who makes one? Let me know please. Thanks
-Chris |
orange914 |
May 15 2007, 11:37 AM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
I'm looking into doing a V8 conversion this summer and I have some questions before I start. Does anyone know if there is an adapting kit for the 901 to bolt up to a Ford block? If so, who makes one? Let me know please. Thanks -Chris which ford engine do you want to install? i myself love the fords, but unfortunately one reason they have lagged behind chevy in hot rod modifications is they dont use a common bell housing pattern. chevy's from 6 cylendars to big blocks share that. i've always thought a SHO 3.0 would be cool in a 914. (IMG:style_emoticons/default/driving.gif) |
skline |
May 15 2007, 11:40 AM
I agree on the SHO engine, all aluminum 3 liter built by Yamaha/Mercury Marine built to rev. Awesome motor! As for adapters, YES, Kennedy engineering makes them and I have seen ford engines in 914's. Not many, but a few. The problem with most is the distributor is in the front making it a bad match for the 914 engine compartment.
Aaron Cox |
May 15 2007, 11:47 AM
ford motors have their dizzy's up front... and they interfere with the front firewall.
when you stick a SBC into the engine bay, you only have to notch the trunck bulkhead to clear the dizzy..... or you could just go crankfire and EFI (IMG:style_emoticons/default/tongue.gif) if i were to stick a v8 in mine (never), i would go northstar, or lexus dohc v8's.... |
Rand |
May 15 2007, 11:54 AM
andys |
May 15 2007, 11:58 AM
Chris,
Kennedy Eng'g. makes the adapter and clutch/flywheel assembly. You can use either the Rennegade or Meziere remote mount water pump, but with the Ford you'll need to deal with the inlets on the timing chain cover that are integral to it. Also, the distributor is at the fornt of the motor so I'm not sure what kind of fit issues you'll have. The SBF block in the same length as a SBC, but the crank dampener sticks out a bit more. This swap has been done before, but I'm not sure how the above issues were dealt with. In a poor for-sale photo of an SBF converted 914 I saw a couple of years ago, it appeared that the seller retained the stock water pump and simply cut into the firewall and built a cover (though it looked to extend into the cabin somewhat). If you look at a late (non MOD) Explorer motor, it has DIS (no distributor), so that may be a possibility. You could run the stock EFI which has a nice stand alone harness to ease the swap. Andys |
skline |
May 15 2007, 04:56 PM
jimkelly |
May 15 2007, 05:49 PM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
man - by law you can do what you want to - but - i have got to say - go sbc and order adaptor kit and cooling system thru renegade and be done with it - or not : )
orange914 |
May 15 2007, 10:50 PM
i still say 3.0 SHO built by ford and yamaha. you can still find them relitively cheap
propricer |
May 15 2007, 11:31 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
Chris / NorCal914 ... like others, I would also recommend SBC over Ford for a variety of reasons - of course, I'm prejudiced since I wrote a book on the SBC type !!!
Why don't you come down to Morgan Hill some weekend and let me take you for a ride in an SBC and we can discuss the advantages / disadvantages - and no, you don't have to buy one of my books !!! If interested, email me at ed.ducey@gmail.com |
BMXerror |
May 16 2007, 01:10 PM
Senior Member Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
BMXerror |
May 16 2007, 01:25 PM
Seriously though, if I were looking for a twin cam, high reving, steal block, V6, I'd have to go with the Mitsubishi 3000gt motor. Shorter stroke than the Ford (76mm to the Ford's 80), good flowing heads, and a bulletproof bottom end. There's guys building turbo versions in excess of 750 WHP, and they're supposedly street cars. Lots of speed equipement for it thanks to a dedicated few.
NO, I doubt anybody makes any adapters for it, so it'd be a lot of work for a little more. I also can't tell you how it would fit, because nobody's ever done it that I know of. It is rather bulky, but I doubt it'd be any more of a problem than an SBC. Action salvage sells rebuilt 3000gt twin cams for $3,200, which is an easy 220 BHP. Just something to throw out there since you seem to still be in the 'engine choosing' stage. I will say, whatever you do, make sure it's somewhat original. Mark D. |
RoninEclipse2G |
May 16 2007, 01:36 PM
Suby Geek Group: Members Posts: 232 Joined: 28-April 07 From: Parker, Colorado Member No.: 7,701 Region Association: Rocky Mountains |
Subaru, similar size and just slightly heavier than a stock 2.0, 227 hp on a turbo wrx 2.0 renegade has the stuff for the conversion, no "major" cutting. flat design keeps the center of gravity lower, not too torquey on the bottom end to tear up a 901, ~ 30mpg (I'd like to see a V8 get that) Is there a downside? I don't see one
Chuck |
May 16 2007, 03:13 PM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
(IMG:style_emoticons/default/agree.gif) What Ronin said. In fact, I am working on it myself.
BMXerror |
May 16 2007, 08:22 PM
Sorry, So Cal. I thought YOU had mentioned the thing about the SHO motor. After reading again I realize you seem to know what you want. Didn't mean to send the thread off on a tangent. The Ford motor I would use would be the 1999-2001 Mustang Cobra motor. Forged crank and twin cam, but still rather square dimensions. Just a thought. I was actually thinking about doing this conversion, but no money. But I can't help you with who sells what and what fits what because, again, I have no money. Again sorry for the hijack. Good luck man, and let us know how it works.
Mark D. |
Lo-Fi Version | Time is now: 15th May 2024 - 04:20 AM |
