55mm blower to HE heater hose... NLA?, No luck at GPR |
bondo |
May 15 2007, 01:01 PM
I'm on the hunt for the correct 55mm heater hose that goes in the engine compartment between the blower and the heat exchangers. The guy at GPR looked through the computer (PET?) and said Porsche was showing the 60mm hose and hose clamps as a replacement. The correct stuff fits so well that it doesn't even need clamps. Is it NLA?
Bartlett 914 |
May 15 2007, 01:13 PM
I'm on the hunt for the correct 55mm heater hose that goes in the engine compartment between the blower and the heat exchangers. The guy at GPR looked through the computer (PET?) and said Porsche was showing the 60mm hose and hose clamps as a replacement. The correct stuff fits so well that it doesn't even need clamps. Is it NLA? One of our Canadian members had it a while back. I can't remember who it was. The hose he had was red. |
Chris Pincetich |
May 15 2007, 03:34 PM
I bought one from Pelican last year = black hose inside engine bay down to J-tubes.
I bought the hose from Mihai (sp?) this year that goes from flapper boxes to hole in body = orange/white tough plastic with metal spiral inside. I have one extra length of this in my garage (IMG:style_emoticons/default/beerchug.gif) |
Eric_Shea |
May 15 2007, 03:56 PM
Bore out a 45mm hose (IMG:style_emoticons/default/wink.gif)
mrhurtalot |
May 15 2007, 03:58 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
pelican has them. i bought both the long and short one
they also have the redish one the the flapper boxes. |
Joe Ricard |
Not for the CW crowd.
I always used the large diameter shop vac hose. Perfect. |
eg914 |
May 16 2007, 12:29 AM
Member Group: Members Posts: 319 Joined: 17-June 04 From: Elk Grove, CA Member No.: 2,223 Region Association: None |
Also not CW, I am using aircraft CAT (black) tubing for the hoses from the fan and SCAT (orange) tubing for the heater valve to body. I think I used 2.25" for the CAT and 2.5" for the SCAT, with hose clamps. Total cost was less than buying just the lower hoses from Pelican.
Lo-Fi Version | Time is now: 14th May 2024 - 11:53 PM |
