identifying a crank |
ws91420 |
May 15 2007, 07:55 PM
Yes I have one a Lensley 914 Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region |
I have a crank that I got w/ the last car I bought. It has been counterweighted. I was wondering how I can identify the stroke and the jounal size?
Jake Raby |
May 15 2007, 08:43 PM
Got any pics?? Thats all I need most of the time!
ws91420 |
May 15 2007, 08:46 PM
not at this time. It is at my mom's house right now along w/ the car. It came with rods as well.
May 15 2007, 10:13 PM
How about measuring them? OK, measuring the stroke requires a little bit of thought, but the journal sizes? Just measure!
For the stroke: Set the crank flat on a table. Put a straight-edge parallel to the crank--measure the distance to the two "near" rod journals and make sure those two numbers are the same. Then measure the distance to the near side of the "far" throws, and re-check the measurement to the near side of the "near" throws. The difference (far - near) in millimeters is the stroke. --DD |
ws91420 |
May 26 2007, 10:11 PM
Got pics of the crank and rods. The crank has been counterweighted.
Attached thumbnail(s) |
craig downs |
May 26 2007, 11:52 PM
Senior Member Group: Members Posts: 768 Joined: 25-November 05 From: mira loma ca. Member No.: 5,189 Region Association: Southern California |
Looks like a stock 2 liter 71mm stroke. Stock 2 liter journals but you have to measure the journals to see if they have been ground. Or if it has been ground they usually stamp the size on the crank. But the best way is to measure it
MrKona |
May 26 2007, 11:57 PM
Senior Member Group: Members Posts: 597 Joined: 25-July 05 From: Santa Rosa, CA Member No.: 4,469 Region Association: None |
That looks like a 2.0L rod. 1.7s and 1.8s have a balancing pad on the small end.
sean_v8_914 |
May 27 2007, 01:55 PM
typical to see a .010-.010 crank when they have been welded up
Measure the journals. a loc al machine shop would probably measure it for free if you dont have the mic |
ws91420 |
May 27 2007, 06:00 PM
bearings included w/ it .25mm rod and mains
Cap'n Krusty |
May 27 2007, 08:38 PM
Give us the part number of the rod bearings. 2 litre RBs start with "039", 1.7/1.8 start with "021". The Cap'n
ws91420 |
May 27 2007, 08:46 PM
200 227 610 VW
sean_v8_914 |
May 28 2007, 03:02 AM
.25mm is 0.010 inches undersized
BarberDave |
May 28 2007, 05:42 PM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I thought " The Cap'n" was the only Crank around here!! Dave (IMG:style_emoticons/default/slap.gif) |
ws91420 |
Jul 11 2007, 08:42 PM
Bump for Jake tonight.
Lo-Fi Version | Time is now: 16th May 2024 - 03:55 AM |
