ws91420
May 15 2007, 07:55 PM
I have a crank that I got w/ the last car I bought. It has been counterweighted. I was wondering how I can identify the stroke and the jounal size?
Jake Raby
May 15 2007, 08:43 PM
Got any pics?? Thats all I need most of the time!
ws91420
May 15 2007, 08:46 PM
not at this time. It is at my mom's house right now along w/ the car. It came with rods as well.
Dave_Darling
May 15 2007, 10:13 PM
How about measuring them? OK, measuring the stroke requires a little bit of thought, but the journal sizes? Just measure!
For the stroke: Set the crank flat on a table. Put a straight-edge parallel to the crank--measure the distance to the two "near" rod journals and make sure those two numbers are the same. Then measure the distance to the near side of the "far" throws, and re-check the measurement to the near side of the "near" throws. The difference (far - near) in millimeters is the stroke.
--DD
ws91420
May 26 2007, 10:11 PM
Got pics of the crank and rods. The crank has been counterweighted.
craig downs
May 26 2007, 11:52 PM
Looks like a stock 2 liter 71mm stroke. Stock 2 liter journals but you have to measure the journals to see if they have been ground. Or if it has been ground they usually stamp the size on the crank. But the best way is to measure it
MrKona
May 26 2007, 11:57 PM
That looks like a 2.0L rod. 1.7s and 1.8s have a balancing pad on the small end.
sean_v8_914
May 27 2007, 01:55 PM
typical to see a .010-.010 crank when they have been welded up
Measure the journals. a loc al machine shop would probably measure it for free if you dont have the mic
ws91420
May 27 2007, 06:00 PM
bearings included w/ it .25mm rod and mains
Cap'n Krusty
May 27 2007, 08:38 PM
Give us the part number of the rod bearings. 2 litre RBs start with "039", 1.7/1.8 start with "021". The Cap'n
ws91420
May 27 2007, 08:46 PM
200 227 610 VW
sean_v8_914
May 28 2007, 03:02 AM
.25mm is 0.010 inches undersized
BarberDave
May 28 2007, 05:42 PM
I thought " The Cap'n" was the only Crank around here!!
Dave
ws91420
Jul 11 2007, 08:42 PM
Bump for Jake tonight.
