Front Bilstein install....Quick question |
Qball |
May 16 2007, 03:47 PM
member Group: Members Posts: 109 Joined: 17-March 06 From: Middle Village NY Member No.: 5,734 |
Where does the little rubber ring go on the front Bilstein's? (IMG:style_emoticons/default/confused24.gif)
Eric_Shea |
May 16 2007, 09:41 PM
Couple of options:
1. Vent Ring = Small ring that is flat with a slice out of it and is just under 1/4" thick. - On the top of the shock body. 2. Rubber snubber - Fairly thick series of donuts meant to offer a final dampening effect if you come close to bottoming out the suspension. - On top of the vent ring but still under the metal dust cover. |
Qball |
May 17 2007, 07:23 AM
Couple of options: 1. Vent Ring = Small ring that is flat with a slice out of it and is just under 1/4" thick. - On the top of the shock body. 2. Rubber snubber - Fairly thick series of donuts meant to offer a final dampening effect if you come close to bottoming out the suspension. - On top of the vent ring but still under the metal dust cover. Thanks Eric, but if I read the directions correctly the Bilsteins don't use the the thick donuts off the stock boges. The smaller 1/4 inch thick washer is the one in question. I don't know if it goes above or below the dust cover.......... (IMG:style_emoticons/default/popcorn[1].gif) |
Eric_Shea |
May 17 2007, 08:08 AM
Qball |
May 17 2007, 09:01 AM
(IMG:style_emoticons/default/beerchug.gif) Thanks
Lo-Fi Version | Time is now: 14th May 2024 - 07:07 AM |
