QUOTE(Eric_Shea @ May 16 2007, 08:41 PM)
Couple of options:
1. Vent Ring = Small ring that is flat with a slice out of it and is just under 1/4" thick. - On the top of the shock body.
2. Rubber snubber - Fairly thick series of donuts meant to offer a final dampening effect if you come close to bottoming out the suspension. - On top of the vent ring but still under the metal dust cover.
Thanks Eric, but if I read the directions correctly the Bilsteins don't use the the thick donuts off the stock boges. The smaller 1/4 inch thick washer is the one in question. I don't know if it goes above or below the dust cover..........
