> Correct fuel pressure for dual carbs?
terrymason
post May 16 2007, 11:16 PM
Post #21
I'm having alittle trouble getting my dual carbs dialed in, the 1st is rich, and the second is lean. My fuel pump was putting out 3.5psi, but the guy I bought my carbs from said I should run 2.6psi instead. What do you guys think?
I've got 60 idle jets and 180 mains, which I thought was overkill, until he told me that I should run 2.6 instead of 3.5 psi.
terrymason   Correct fuel pressure for dual carbs?   May 16 2007, 11:16 PM
john rogers   I ran 3.5 PSI with my four cylinder engines and ab...   May 17 2007, 12:23 AM
So.Cal.914   3.0 lbs.   May 17 2007, 02:03 AM
lotus_65   2.5 lbs   May 17 2007, 06:25 AM
SGB   60s are mighty big. How big is the motor? for ma...   May 17 2007, 06:59 AM
type11969   The self-regulated pumps sold by VW shops for dual...   May 17 2007, 08:33 AM
rhodyguy   any other symptoms? snapping/popping back thru the...   May 17 2007, 09:35 AM
terrymason   any other symptoms? snapping/popping back thru th...   May 17 2007, 09:45 AM
terrymason   I'm running 60 idle jets, 140 main jets, and 1...   May 17 2007, 09:39 AM
rhodyguy   sometimes a bit more info is helpful. no mention o...   May 17 2007, 09:52 AM
terrymason   sometimes a bit more info is helpful. no mention ...   May 17 2007, 10:34 AM
type11969   If you have the dellorto superperformace tech book...   May 17 2007, 09:58 AM
rhodyguy   the only reason i suggest turning the idle up is t...   May 17 2007, 10:49 AM
Travis Neff   does your pump rattle a bunch? That would be an i...   May 17 2007, 10:57 AM
terrymason   does your pump rattle a bunch? That would be an ...   May 17 2007, 11:22 AM
type11969   Check to make sure your idles are clear, also veri...   May 17 2007, 11:00 AM
terrymason   I talked to Aaron from CB performance, who was awe...   May 17 2007, 11:08 AM
Gint   I talked to Aaron from CB performance, who was aw...   May 17 2007, 05:36 PM
rhodyguy   "no ammount of adjustments"...are you re...   May 17 2007, 11:15 AM
terrymason   "no ammount of adjustments"...are you r...   May 17 2007, 11:18 AM
type11969   Plugged idle jet or circuit   May 17 2007, 11:16 AM
Travis Neff   Sounds like you do have a facet pump. The CB rota...   May 17 2007, 11:24 AM
rhodyguy   facets suck. get #3193. the canister to the right ...   May 17 2007, 11:34 AM
terrymason   I have some 46 and 52 idle jets at home (60s insta...   May 17 2007, 02:18 PM
type11969   I'm running a 1.8, little warmed over than sto...   May 17 2007, 02:39 PM
anderssj   Terry, I have some spare jets here in Yorktown--m...   May 17 2007, 04:01 PM
type11969   :agree: I fought with my dells and got sick of s...   May 17 2007, 06:38 PM
r_towle   You may have a simple air leak at the intake bolts...   May 17 2007, 09:50 PM
terrymason   Well, I believe that I've found the main probl...   May 17 2007, 10:10 PM
Gint   It just plain makes good sense. You'll establ...   May 17 2007, 10:18 PM
terrymason   I'm still fighting this thing, and am ready to...   Jun 3 2007, 05:00 PM
- Lo-Fi Version Time is now: 11th July 2025 - 05:57 AM
