Engine tin identification -- what is this? |
toomanyinkc |
May 18 2007, 02:50 PM
Member Group: Members Posts: 67 Joined: 8-February 07 From: Kansas City Member No.: 7,509 |
These were in the boxes-o-parts that came with the car. Where do they go?
Does this one go above the oil cooler? I've spent quite a bit of time looking at parts diagrams but haven't solved this mystery. |
Bartlett 914 |
May 18 2007, 02:55 PM
Engine cooling tins. Top one goes next to one of the cylinders (can't remember which one. The bottom goes near the oil cooler.
TravisNeff |
Second one is for the oil cooler. first one goes on the rear of the engine, if I remember right.
toomanyinkc |
May 18 2007, 03:06 PM
still don't get it...can someone identify them on the diagram? Looks like my second pic is #24? Is the oil cooler below it? |
John |
May 18 2007, 03:17 PM
As the exploded view shows, the first piece is the drivers side closest to the fan housing, front side of cylinder, the second piece is the passenger side closest to the fan housing, front side of cylinder (where the oil cooler is). The opening on the second piece allows cool air to be directed to the oil cooler.
Good luck. just my $0.02 |
skline |
May 18 2007, 03:20 PM
The first picture is number 17 in your diagram (IMG:style_emoticons/default/smile.gif)
So.Cal.914 |
May 18 2007, 05:17 PM
Passing thru
I now see you have the dia. I was going to give you. Attached thumbnail(s) |
May 18 2007, 08:24 PM
The first is #17, and it goes between the driver's side cylinder head and the alternator.
The second is #24, and it goes on top of the oil cooler and in front of the passenger's side cylinder head. --DD |
toomanyinkc |
May 18 2007, 09:46 PM
Thank you!!! I had today off work and it seems like I didn't get anything done on the car - but I did learn where some parts go and determined some more parts that I need. I now see that this is going to be a very slow process.
Lo-Fi Version | Time is now: 15th May 2024 - 04:43 PM |
