Cracked heads, No I am not a crack head |
Bartlett 914 |
May 18 2007, 04:42 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
About this time last year I had a problem with my 2.0.
http://www.914world.com/bbs2/index.php?sho...c=51716&hl= Lately I started working on this motor. It is unbelievable all the problems I have found. First I found Bus pistons and .063 in shims giving me a very low CR. I decided to check my valve guides. I borrowed a compressor from Glenn Stazak and removed the valves. I found my problem with cylinder 3. Intake seat totally loose. I also found cracks. I thought they were repaired (back in 88). The shop only installed heli-coils in the spark plug holes. No welding. I started what I had hoped to be a reseal job. (IMG:style_emoticons/default/headbang.gif) Attached image(s) |
Jake Raby |
May 18 2007, 05:04 PM
Totally typical..It was ran out of tune or someone didn't know how to use 5th gear...
Send the heads straight to www.haminc.biz or just buy some LE 180s and be done with it for another 20 years :-) |
Bartlett 914 |
May 18 2007, 05:37 PM
Totally typical..It was ran out of tune or someone didn't know how to use 5th gear... Send the heads straight to www.haminc.biz or just buy some LE 180s and be done with it for another 20 years :-) Hi Jake I know. That is an excellent idea and probably one I will pursue at a later date. This engine is the one with the bus pistons. I have another motor that I had planned to use with one of your kits. I will steal the heads from that motor. Later when I am ready for that rebuild, I will pony up. Right now, I need a decent motor for my DD using all the stuff I have collected. |
Lo-Fi Version | Time is now: 13th May 2024 - 11:22 PM |
