> '73 1.7L won't hold idle
rettigdw914
post May 18 2007, 08:20 PM
Long time reader, first time poster here. If it wasn't for all of the great info on this site, I wouldn't have come half as far as I have on this project.
The problem I am having is at 60degF. ambient, cold engine, the car starts, jumps to 2000rpm for about 5seconds, then sputters and dies. It is very repeatable.
Does this sound like a vacuum leak or ignition problems or other?
Parts replaced/checked:
Rebuilt fuel pump(30psi solid),
Injectors flow tested and ultrasonically cleaned(4ml for 10sec crank)
Rebuilt MPS from Bret, also used another Bosch original.
Used two different ECMs
TPS calibrated
All electrical loads to ECU resistance checked per pbanders site.
All Vacuum lines replaced, not all German hose but has good fit
Injector seals replaced
Intake runner gaskets and hose to plenum replaced
Checked cork gasket on oil fill cap and is old but sealing
Rebuilt distributor
New points,condenser,cap,rotor,coil, wires,plugs(.024")
Dwell is 42deg., out of spec. but should still run. right?
Timing set to 27 deg bef. TDC, but I have been moving the dizzy around.
Valves checked, OK
I might try the carb cleaner trick to check for vacuum leaks but any other ideas are appreciated and welcomed.
Things not replaced are: TPS gasket, Cold start seal?, AAR(it is open, not sure if closes)
Thanks,
-Don
rettigdw914   '73 1.7L won't hold idle   May 18 2007, 08:20 PM
sendjonathanmail   haha...carb cleaner....what an experience..:D :D :...   May 18 2007, 08:28 PM
r_towle   If the car only runs for 5 seconds, how do you kno...   May 18 2007, 10:35 PM
Bleyseng   :agree:   May 18 2007, 11:40 PM
rettigdw914   Thanks for the input guys, maybe I will hold off o...   May 19 2007, 03:57 PM
rettigdw914   OK, I had the neighbor come over and watch the fue...   May 20 2007, 08:21 PM
r_towle   ok, You are getting an initial blast of fuel, and ...   May 20 2007, 10:16 PM
Travis Neff   Make sure that your FI trigger points are plugged ...   May 21 2007, 10:59 AM
bd1308   3 prong connector does the fuel pump turn on for ...   May 21 2007, 11:02 AM
rettigdw914   Update: the Fuel pump does spin at key-on and i c...   May 21 2007, 09:25 PM
John   I see two things that confuse me with your picture...   May 21 2007, 10:05 PM
rettigdw914   The hose to the fan shroud goes back to the charco...   May 22 2007, 01:27 PM
rettigdw914   Update: I pulled one of the injectors out and put ...   May 22 2007, 08:54 PM
rettigdw914   Update: I took a look at me fuel filter and there ...   Jul 5 2007, 12:41 PM
Dave_Darling   Pulled hose from MPS == high pressure to MPS. The...   Jul 5 2007, 06:32 PM
rettigdw914   Thanks Dave. I kinda suspected that. Wonder if s...   Jul 6 2007, 09:32 AM
Bartlett 914   links to an "economical" professional...   Jul 6 2007, 10:40 AM
rettigdw914   Final Update: I found rust chips in my injectors...   Jul 16 2007, 11:25 AM
- Lo-Fi Version Time is now: 30th June 2025 - 10:06 PM
