Plugs and Gap, What are yours? |
redshift |
Dec 8 2003, 07:52 AM
I'm running stock fi euro 2.0.
What plugs and gap are you using on your similar motor? Just wondering. M |
ArtechnikA |
Dec 8 2003, 08:11 AM
QUOTE(redshift @ Dec 8 2003, 05:52 AM) I'm running stock fi euro 2.0. What plugs and gap are you using on your similar motor? what ignition ? if stock, it's hard to beat Bosch copper plugs gapped per the spec book. HiPo ignitions go bigger. i'm using 0,040" with my HI-6, reduced from 0,044" just to eliminate any possibility of problems while i was stalking my bad-running issues. now that i've got that resolved i'll probably bump them back open to 0,045" again ... |
redshift |
Dec 8 2003, 08:39 AM
I'm just wondering if there are options out there that make any difference on a completely stock setup.
On another topic.. somewhat relative... Gas futures... I think you need to invest in petroleum futures... there is going to be an early January rush for another mix, at least here. M |
ArtechnikA |
Dec 8 2003, 08:50 AM
QUOTE(redshift @ Dec 8 2003, 06:39 AM) I'm just wondering if there are options out there that make any difference on a completely stock setup. you might see a teeny improvement with Denso finewire iridium. they probably won't make enough difference to be worth the ~$12/plug cost tho. (January rush for another mix? i'm sorry, i'm not following you ...) |
redshift |
Dec 8 2003, 08:57 AM
I was just noting that the early cold fuel formulas (my coast) are not working, makes gas prices go up next qtr..
Since they are down, makes a good time to buy a few, and get ready to short some more. (IMG:style_emoticons/default/smile.gif) M |
ArtechnikA |
Dec 8 2003, 09:03 AM
QUOTE(redshift @ Dec 8 2003, 06:57 AM) Since they are down, makes a good time to buy a few... actually, i'm on my way to buy 500 gallons of heating oil. the price was less than i was expecting; perhaps this is indeed a good time... |
Brett W |
Dec 8 2003, 11:20 AM
I have never had any success with Bosch Plugs, Get a set of NGK B7ES for a stock motor and run them at .030 your engine will run great.
redshift |
Dec 8 2003, 02:01 PM
Gint |
Dec 8 2003, 06:13 PM
Mike Ginter Group: Admin Posts: 16,071 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
I pretty much use standard copper NGK's in any car I'm planning on keeping. And I don't have a running 914 at the moment, so I'll skip answering the gap question.
Drums66 |
Dec 8 2003, 11:51 PM
The last set of Bosch plugs I used lasted for a year or so....I might have pushed it but they were good to go fired beautiful! they were super Bosch and that's what I replaced them with. Gap .028 but I agree NGK is a fine plug. I'm talking T-4 2.0 (IMG:style_emoticons/default/boldblue.gif)
ChrisReale |
Dec 8 2003, 11:59 PM
Bosch W7CC's and stock gap. magnacore wires. I let the hamsters smoke crack tho, so I get a few more ponies outta them, but it gets expensive (IMG:style_emoticons/default/unsure.gif)
redshift |
Dec 9 2003, 02:45 AM
Gap has alot to do with CH temps, huh?
M |
Lo-Fi Version | Time is now: 15th May 2024 - 12:43 PM |
