Hose adapters needed, Stupid water cooled engines. |
TonyAKAVW |
May 21 2007, 11:49 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
So yesterday I was all set to complete my conversino from mid-mounted radiator to front mounted radiator. After getting the hose in place I discovered that I had made a stupid mistake. While the radiator uses 1 1/4 inch hose, the engine uses 1 1/2 inch hose. Being that it was Sunday the only option I had was Home Depot. They had nothing useful. So now I'm trying to find a couple of reducers. Of the several radiator shops I called near me, I found that one has a "bucket full of adapters." I'm going to check that out at lunch time but would like a backup plan if that fails.
Any ideas? time is of the essence here, as I need to get the system filled bled, tested and proven this week. -Tony |
bondo |
May 21 2007, 12:16 PM
What about mcmaster part number 45605K726?
nick mironov |
May 21 2007, 12:28 PM
nickm Group: Members Posts: 204 Joined: 12-June 05 From: San Francisco, CA Member No.: 4,264 |
I think what you want is on page 252 of the McMaster Carr catalog - Easy-Fit Hose Fittings (part number 5363K54 - or similar). That is what I uesd for my application. See attachment 252 below - this is a pdf of page 252 of th catalog.
Nick Attached image(s) Attached File(s) 0252.pdf ( 93.89k ) Number of downloads: 1279 |
TonyAKAVW |
May 21 2007, 12:32 PM
Looks like none of those come in the right sizes. Bondo: that part number _could_ be used with modifcation I suppose......
-Tony |
andys |
May 21 2007, 12:37 PM
Tony,
Don't know if this is what you need, but Summit has this: # SUM-390124-R Andys |
dlo914 |
May 21 2007, 01:52 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
OT: But thought this might come in handy. Tony i remembered when we pulled the 5 lug suspension off the silver tub that one side of the rear suspension was missing the e-brake. IIRC just this past week when i went to the Pick-A-Part in El Monte there was an early model 911 that still had the rear suspension w/ the inner rotor e-brake. Other than that everything else on the car was stripped. Dunno if you ever found a replacement, but just thought this might help if you're still looking for one. (IMG:style_emoticons/default/smile.gif) Now back to your regular thread topic.
notbobvilla |
May 21 2007, 09:25 PM
Newbie Group: Members Posts: 11 Joined: 8-May 07 From: Hartford Michigan Member No.: 7,729 |
Hopefully this helps..............
Ren'e First try adding pics..... (IMG:style_emoticons/default/unsure.gif) Opps Mfg by Dayco, any FLAPS around 6 bucks. Attached image(s) |
GS Guy |
May 22 2007, 10:45 AM
Member Group: Members Posts: 243 Joined: 8-July 04 From: Columbia, MD Member No.: 2,325 Region Association: North East States |
Tony,
I've also been looking for said hose adapters. I know your build is sort of "non-Renegade" oriented, but I think they're likely the best bet for the adapters. I haven't found anything else out there that isn't some sort of iron-pipe hardware store kludge. I think the Renegade adapters are $30 for the pair? I'd still like to find a reducer for the upper hose connection that has a fitting in the middle for an air purge similar to the aftermarket in-line temperature sending unit adapters. Jeff |
TonyAKAVW |
May 22 2007, 08:49 PM
Well, I called Renegade and thy don't have the size I need...
Those Dayco parts seem to be good only for making a smaller port work with larger hose. I have 1.25 inch hose that needs to connect to 1.5 inch ports on the engine. Until I can turn down some proper adapters on a lathe I'm thinking of doing as in the figure below. I figure that the friction of rubber against rubber ought to hold the hose, not to mention that the 1.5 inch hose will have to stretch to fit over the 1.25 inch hose. Anyone think this will work? -TOny Attached image(s) |
GS Guy |
May 23 2007, 07:33 AM
I think that would seal - but nothing keeping it from blowing apart?
If there's any chance you can get some time on a lathe - I think there's a McMaster Carr part that could be modified to work? Check out PN: 5363K24. It's an aluminum hose fitting, 1-1/4 hose to 1-1/4 NPT. According to my Pipe thread diagrams that 1-1/4NPT measures a little over 1.5" diameter at the small end. I think you could turn off the NPT taper and threads - making the threaded end smooth with a small lip on the end for hose retention? If done carefully I think you could even grinf off most of the threads on a belt sander - just need a smooth portion for the hose to seal against. For about $8 seems worth a try... (IMG:style_emoticons/default/idea.gif) Sounds like the radiator shop "bucket of adapters" didn't pan out? Also a number of inline hose connectors and gauge sensor adapters available from Pegasus - get a 1.25-1.25 and use the Dayco part to step up to 1.5? http://www.pegasusautoracing.com/advcat.as...egoryID=COOLING Jeff Well, I called Renegade and thy don't have the size I need... Those Dayco parts seem to be good only for making a smaller port work with larger hose. I have 1.25 inch hose that needs to connect to 1.5 inch ports on the engine. Until I can turn down some proper adapters on a lathe I'm thinking of doing as in the figure below. I figure that the friction of rubber against rubber ought to hold the hose, not to mention that the 1.5 inch hose will have to stretch to fit over the 1.25 inch hose. Anyone think this will work? -TOny |
GS Guy |
May 23 2007, 07:37 AM
Or better yet - use the Pegasus silicone hose reducer to get you from 1.5 to 1.25 and than a straight 1.25 connector? Not cheap, but a permanent solution.
sakitume |
May 23 2007, 02:39 PM
Newbie Group: Members Posts: 6 Joined: 25-September 06 Member No.: 6,919 |
Tony. Have you tried the folks at JagsThatRun (Stealth Conversions)? Check this page out:
http://www.jagsthatrun.com/Pages/Parts_DAT...Splice-Kit.html You'll see that they sell a "reducer bushing" that lets you go from 1.5 to 1.25 like you're intending to do. Hmmm....the bushing seems to function in a similar manner as what you're doing with the doubled up hoses. Cheers, Donovan |
Phoenix-MN |
May 23 2007, 03:13 PM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Check out NAPA they have a very large selection
http://www.napabeltshose.com/downloads/fil...UIDE_FORWEB.pdf Look at the list ordered by inside diameters |
fiid |
May 23 2007, 06:08 PM
Well, I called Renegade and thy don't have the size I need... Those Dayco parts seem to be good only for making a smaller port work with larger hose. I have 1.25 inch hose that needs to connect to 1.5 inch ports on the engine. Until I can turn down some proper adapters on a lathe I'm thinking of doing as in the figure below. I figure that the friction of rubber against rubber ought to hold the hose, not to mention that the 1.5 inch hose will have to stretch to fit over the 1.25 inch hose. Anyone think this will work? -TOny NO! You need a lip on both ends of whatever is on there. Ask me how I know (IMG:style_emoticons/default/smile.gif) I used copper fittings with the right OD from home depot. Then I took a brass halfround and made a ring and soldered it onto the end of the copper. I made it to the WCC in Portland and back again without the lips on the fittings. Then I got a triple-A call the next time I drove it. (IMG:style_emoticons/default/biggrin.gif) |
May 23 2007, 06:10 PM
How about the correct sized muffler pipe adapter.
the little 4 inch ones that go from one size pipe to another. Get on that fits inside both, slide them on all the way and apply a screw clamp. You wont be able to see it. Rich |
TonyAKAVW |
May 24 2007, 01:15 AM
The muffler adapter might work. There's a muffler shop near where I live. I might go by there at lunch tomorrow and see what they can do. I just don't know if I can trust them to expand tubing the 1.5 inch outer diameter, and if they even have 1.25 inch outer diameter tubing.
Fiid: I know of your barb-less woes and thats why I'm trying to do the right thing here. I'm just not finding a way out of this that doesn't involve waiting for soemthing to be shipped here. My next option is to pick up some aluminum tomorrow at lunch and try to find some time on a lathe to turn some parts out. I have a tiny Sherline lathe at home that _might_ work if I could get 1.5 inch thick walled aluminum pipe. 0.175 inch wall thickness if i want 50 mil thick walls for the smaller end. That might work. hmm. -Tony |
TonyAKAVW |
May 24 2007, 12:10 PM
Okay, final solution figured out.
I called M&K Metals (my local hobbyist friendly metal supplier) and for $10 I'm getting a foot of 1.5 inch O.D. 1/4 inch wall aluminum tube. Andrew (phantom914), is lending me his lathe and bandsaw to make these pieces. So hopefully tonight I'll have the adapters done. Anyone else in desperate need for adapters of this size? I should have plenty of leftover material. They will be made as in the diagram below... the 1.5 inch side will be held on by machining a shallow recess in the alumium. Machining out a barb would require a thicker piece, and the next size up is 1.75 inch, which might not hae a thick enoguh wall for a 1.25 inch side. And I really don't want to hog out a solid bar of aluminum. If this recess doesn't hold the hose on, then I'll get a bead of weld put at the end, and machine as required. -Tony Attached image(s) |
TonyAKAVW |
May 25 2007, 02:09 AM
DONE.
Also made a fitting for the overflow tank/reservoir. Attached image(s) |
GS Guy |
May 25 2007, 07:32 AM
Nice work Tony! Those should work out great.
Jeff |
RoninEclipse2G |
May 25 2007, 10:19 AM
Suby Geek Group: Members Posts: 232 Joined: 28-April 07 From: Parker, Colorado Member No.: 7,701 Region Association: Rocky Mountains |
very nice!
Lo-Fi Version | Time is now: 16th May 2024 - 02:26 AM |
