Need Limited slip diff, I WANT MORE TRACTION |
Joe Ricard |
May 23 2007, 08:21 AM
Ok, so now that we have stepped up the game and have found more lateral cornering G's I am in lifting the inside rear tire again.
No rear sway (of course) High rebound rear shocks 200 lb rear coil over. high rebound koni race shock and 21mm torsion bars in front with 22 Weltmiester bar. set as much as I can before the car pushes. So looking for advise on LSD what's available and what's the difference of each in an autocross application. |
SirAndy |
May 23 2007, 09:58 PM
Resident German Group: Admin Posts: 41,650 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
No rear sway (of course) you got a cage? if so, a rear bar can be beneficial in keeping both wheels on the ground ... not as good as a LSD, but worth a shot. oh, and 200lbs seems a bit soft. i run 250lbs and feel like i could still go a bit stiffer ... i also run a stock rear swaybar. much less wheel-spin than i used to have. (IMG:style_emoticons/default/bye1.gif) Andy |
Lo-Fi Version | Time is now: 20th May 2024 - 01:36 PM |
