A-arm question |
A-arm question |
echocanyons |
Dec 8 2003, 05:13 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Is this the mount for a underbody swaybar from a 911?
Is it somehow compatible with the throughbody sway bar? Is it just welded on? Attached image(s) |
Aaron Cox |
Dec 8 2003, 05:21 PM
thats for the underbody 74+ 911 swaybar
Mueller |
Dec 8 2003, 05:35 PM
You'll need to cut and grind that mount off for a thru body style bar.
These are from Tarett Engineering (IMG:http://www.tarett.com/images/Products/911%20u-brkt.jpg) They are the weld on style (how the factory did it.) |
Jeroen |
Dec 8 2003, 05:50 PM
Just grind those off and weld the "old style" ones back on...
(IMG:http://www.rennware.com/prod/swaybar/911_sway14.jpg) under-body swaybar a-arm on the right, modified a-arm on the left cheers, Jeroen |
Jeroen |
Dec 8 2003, 05:54 PM
Here's the location of the weld on u-tab
cheers, Jeroen Attached image(s) |
echocanyons |
Dec 8 2003, 06:14 PM
Who could ask for more?
Thanks again guys |
Eric_Shea |
Dec 9 2003, 08:35 AM
Or... you could buy my 20mm "underbody" sway bar for dirt. (IMG:style_emoticons/default/smile.gif)
Blasted clean... POR-15'd. Ready to bolt on. E. Attached image(s) |
Dec 9 2003, 06:39 PM
Jeroen...
I cant find 12CM anywhere on my tape measure????? (IMG:style_emoticons/default/cool_shades.gif) |
redshift |
Dec 9 2003, 06:45 PM
QUOTE(Eric_Shea @ Dec 9 2003, 10:35 AM) Or... you could buy my 20mm "underbody" sway bar for dirt. (IMG:style_emoticons/default/smile.gif) Blasted clean... POR-15'd. Ready to bolt on. E. 'Scuse me, I need a bar.. what do I need to make that freak contraption work? (IMG:style_emoticons/default/smile.gif) M |
Jeroen |
Dec 9 2003, 07:29 PM
QUOTE(r_towle @ Dec 10 2003, 02:39 AM) Jeroen... I cant find 12CM anywhere on my tape measure????? (IMG:style_emoticons/default/cool_shades.gif) If you like, I can sell you one that does. They are rare and expensive though, so be prepared to pay serious money (IMG:style_emoticons/default/wink.gif) cheers, Jeroen |
Eric_Shea |
Dec 10 2003, 12:15 PM
QUOTE what do I need to make that freak contraption work? Those mounts that Kelly's about to cut off (IMG:style_emoticons/default/smile.gif) |
stock93 |
Dec 10 2003, 03:42 PM
Member Group: Members Posts: 333 Joined: 12-May 03 From: Huntsville, AL Member No.: 684 Region Association: South East States |
Hey M,
Better get some metric cresent wrenches while your at it too. John |
Brad Roberts |
Dec 10 2003, 03:49 PM
Another reason why I like the SmartCamber bars.... it doesnt use that tab/bracket.
B |
redshift |
Dec 10 2003, 03:55 PM
I had a 911 with an underbody bar, but I never even looked up under there..
I think I like that, it's funky. Anyone have a good set of a-arms with the mounts already there... besides the ones that are being mangled upthread? (IMG:style_emoticons/default/laugh.gif) M |
Qarl |
Dec 10 2003, 04:11 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
I just cut the mounting tabs off and will be using the Smart Racing Bar.
I was getting ready to weld new ones on when Mueller clued me in that the SRB clamps onto the diagonal supports on the A-arms. |
echocanyons |
Dec 10 2003, 06:32 PM
any pictures of how the SRB mounts?
Brad Roberts |
Dec 10 2003, 09:26 PM
I cant find a installed pic on the control arm.. but you will get the idea from this pic.
The part with the arrow clamps around the round support tube on the control arm. Some think this setup keeps the drop link out of potential bind when you set the bar on full stiff (because of its location relative to the drop link) B |
Joe Bob |
Dec 10 2003, 09:35 PM
QUOTE(Eric_Shea @ Dec 9 2003, 06:35 AM) Or... you could buy my 20mm "underbody" sway bar for dirt. (IMG:style_emoticons/default/smile.gif) Blasted clean... POR-15'd. Ready to bolt on. E. I got a front and rear set of those laying around as well.... |
echocanyons |
Dec 10 2003, 09:48 PM
I Appreciate the offer on the undermount bars but I would like to utilize my existing welt bar till I can afford something prettier like the SRB
Lo-Fi Version | Time is now: 14th May 2024 - 12:02 PM |
