echocanyons
Dec 8 2003, 05:13 PM
Is this the mount for a underbody swaybar from a 911?
Is it somehow compatible with the throughbody sway bar?
Is it just welded on?
Aaron Cox
Dec 8 2003, 05:21 PM
thats for the underbody 74+ 911 swaybar
Mueller
Dec 8 2003, 05:35 PM
You'll need to cut and grind that mount off for a thru body style bar.
These are from
Tarett EngineeringThey are the weld on style (how the factory did it.)
Jeroen
Dec 8 2003, 05:50 PM
Just grind those off and weld the "old style" ones back on...
under-body swaybar a-arm on the right, modified a-arm on the left
cheers,
Jeroen
Jeroen
Dec 8 2003, 05:54 PM
Here's the location of the weld on u-tab
cheers,
Jeroen
echocanyons
Dec 8 2003, 06:14 PM
Who could ask for more?
Thanks again guys
Eric_Shea
Dec 9 2003, 08:35 AM
Or... you could buy my 20mm "underbody" sway bar for dirt.
Blasted clean... POR-15'd. Ready to bolt on.
E.
r_towle
Dec 9 2003, 06:39 PM
Jeroen...
I cant find 12CM anywhere on my tape measure?????
redshift
Dec 9 2003, 06:45 PM
QUOTE(Eric_Shea @ Dec 9 2003, 10:35 AM)
E.
'Scuse me, I need a bar.. what do I need to make that freak contraption work?
M
Jeroen
Dec 9 2003, 07:29 PM
QUOTE(r_towle @ Dec 10 2003, 02:39 AM)
Jeroen...
If you like, I can sell you one that does.
They are rare and expensive though, so be prepared to pay serious money
cheers,
Jeroen
Eric_Shea
Dec 10 2003, 12:15 PM
Those mounts that Kelly's about to cut off
stock93
Dec 10 2003, 03:42 PM
Hey M,
Better get some metric cresent wrenches while your at it too.
John
Brad Roberts
Dec 10 2003, 03:49 PM
Another reason why I like the SmartCamber bars.... it doesnt use that tab/bracket.
B
redshift
Dec 10 2003, 03:55 PM
I had a 911 with an underbody bar, but I never even looked up under there..
I think I like that, it's funky.
Anyone have a good set of a-arms with the mounts already there... besides the ones that are being mangled upthread?
M
Qarl
Dec 10 2003, 04:11 PM
I just cut the mounting tabs off and will be using the Smart Racing Bar.
I was getting ready to weld new ones on when Mueller clued me in that the SRB clamps onto the diagonal supports on the A-arms.
echocanyons
Dec 10 2003, 06:32 PM
any pictures of how the SRB mounts?
Brad Roberts
Dec 10 2003, 09:26 PM
I cant find a installed pic on the control arm.. but you will get the idea from this pic.
The part with the arrow clamps around the round support tube on the control arm.
Some think this setup keeps the drop link out of potential bind when you set the bar on full stiff (because of its location relative to the drop link)
B
Joe Bob
Dec 10 2003, 09:35 PM
QUOTE(Eric_Shea @ Dec 9 2003, 06:35 AM)
E.
I got a front and rear set of those laying around as well....
echocanyons
Dec 10 2003, 09:48 PM
I Appreciate the offer on the undermount bars but I would like to utilize my existing welt bar till I can afford something prettier like the SRB
