Removing mirror from windshield |
GaroldShaffer |
May 26 2007, 10:34 PM
OK so what is the best way to remove a rearview mirror from the windshield? I have 76 parts car with a nice mirror I want to keep. Windshield has cracks so I am not concerned about saving the glass. Is there a way to heat he glass so the glue will soften? Will that work? I'm one step away from using a hammer to break the glass around the mirror base and deal with the small glass chunks later.
Thanks (IMG:style_emoticons/default/smash.gif) |
jonferns |
May 26 2007, 10:41 PM
i would imagine that a blowdryer, either from the outside or inside near the base of the mirror, would soften up the adhesive enough to pull it off....(IMG:style_emoticons/default/biggrin.gif) good luck...--JON
So.Cal.914 |
May 26 2007, 11:21 PM
(IMG:style_emoticons/default/agree.gif) But you might want to try a heat gun (super blowdryer) Or, and this is
the one I would use, a mapp gas torch from the outside. |
gregrobbins |
May 27 2007, 12:37 AM
Member: Team NARP Group: Members Posts: 1,515 Joined: 23-March 04 From: Arizona Member No.: 1,844 Region Association: Southwest Region |
Hammer away. Windsheild wont shatter. Pop it a good one on the button.
Or bring the car out to a Arizona summer. They all seem to fall off in the 110* days when the interior of a car can get up to 160 or hotter. |
May 27 2007, 01:55 AM
Hammer away. Windsheild wont shatter. Pop it a good one on the button. (IMG:style_emoticons/default/agree.gif) i just did that 3 weeks ago. used a razorblade to clean up glue around the base and then hit it flat (alongside the surface of the glass) ... (IMG:style_emoticons/default/smash.gif) popped right off with the glass still intact ... (IMG:style_emoticons/default/cool_shades.gif) Andy |
gopack |
May 27 2007, 07:27 AM
CHEESEHEAD in CA, MARK Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California |
Here is the technique I used to remove my mirror when i first got my 914:
1) Grasp mirror firmly 2) gently try to adjust mirror to see out small back window 3) Toss mirror into passenger foot well 4) drive away! I couldn't keep mine attached, so coming off shouldn't be much of a problem! |
woobn8r |
May 27 2007, 08:31 AM
Senior Member Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None |
Can you get a wire in behind?...a guitar string, piano wire or other suitable strength wire should slice it off nice (with some heat too)...
S. |
BarberDave |
May 28 2007, 05:19 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
Garold: I am with ( gopack), when i had the stock one it keep falling off. Get the one that mounts to the center bracket of your sun visors. Dave (IMG:style_emoticons/default/smilie_pokal.gif) |
aircooledboy |
May 28 2007, 10:29 AM
Sweet Pea's 1st ride in daddy's "vroom -vroom" Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest |
At the glass shop we would just lay the glass flat, mirror up, pour a small puddle of alcohol around the base, and light it. After a few seconds, twist the base with a pair of channel locks, and it should come right off. With a windshield you don't care about, you can just heat the back side with a torch. Same twisting procedure and it should pop right off. (IMG:style_emoticons/default/beerchug.gif)
PinetreePorsche |
May 28 2007, 09:49 PM
Member Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
My windshield is a recent one, and the PO may have wut the mirrowr on too high--either that or the r springs are really shot--and they don't feel like it on the road or a-x track. I want to move it down WITHOUT destroying the glass. I would consider the fine piano wire, but feel it's on real well, so want some other hints or tricks. Anyone got any?
GaroldShaffer |
May 28 2007, 10:25 PM
I heat the glass with torch and gave it a good (IMG:style_emoticons/default/smash.gif) small part of the windshield came off with it but I don't care. Thanks everyone.
bulitt |
Feb 24 2014, 10:29 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Old thread...So trying to take the mirror off a chipped windshield. Heated it, pried on it, beat it. Heated the heck out of it with my heat gun. To no avail. Figured I would just leave it before I got hurt. Opened the garage door to walk out and mail a letter and heard a pop. Cold air must have contracted the glass and popped it off.
Whatever (IMG:style_emoticons/default/lol-2.gif) |
Lo-Fi Version | Time is now: 14th May 2024 - 01:35 AM |
