longitudinal construction, what does it look like inside? |
obscurity |
May 28 2007, 04:58 PM
Member Group: Members Posts: 411 Joined: 24-February 06 From: Atlanta ,GA Member No.: 5,628 Region Association: South East States |
As I understand it the long consists of two "C" shaped halves. Each half consists of an outer skin and an inner stiffener. Upon disection of my hell hole I know this to be the case at the engine compartment. My question is how far forward does the inner stiffener extend?
I have not opened the front area up yet but I was hoping to find out what I should expect. Thanks, John |
McMark |
May 28 2007, 05:22 PM
I just bumped my old thread. (IMG:style_emoticons/default/wink.gif)
So.Cal.914 |
May 28 2007, 05:27 PM
obscurity |
May 28 2007, 05:51 PM
Thanks!! Based on the posts so far it looks like the stiffener only goes as far forward as the seatbelt anchor (and barely that far)
McMark |
May 28 2007, 07:39 PM
I think what you're calling the 'stiffener' is actually the heater tube... I can't imagine what else starts at the hell hole and goes to the seat belt anchor. (IMG:style_emoticons/default/confused24.gif)
obscurity |
May 28 2007, 08:28 PM
I think what you're calling the 'stiffener' is actually the heater tube... I can't imagine what else starts at the hell hole and goes to the seat belt anchor. (IMG:style_emoticons/default/confused24.gif) I'm pretty sure there is an inner (thicker) piece of steel inside the long that starts just in front of the trunk and runs to the lower seatbelt attachment point. It is spot welded to the inside of the long. If you buy a replacement upper and lower wheel house panel it has the "stiffener" prewelded in I'm sure "stiffener" is not the accepted term but I'm not sure what is the arrow points to the part I'm talking about at the seatbelt. Am I wrong in thinking that it extends back along the longitudinal to somewhere around the trunk? |
May 28 2007, 08:58 PM
I think "reinforcement" would be a more apt description. You can see the end in that picture there--it just goes for a little while around the seat belt mount, and that's it.
Oh, and remember--that pic you reposted is the back part of the tunnel. --DD |
McMark |
May 28 2007, 11:26 PM
Ahhhhhhh, right on. You are correct! That is the corrugated piece seen above.
Lo-Fi Version | Time is now: 14th May 2024 - 07:00 PM |
