901 rebuild, gear ratio suggestions |
DanT |
May 28 2007, 08:18 PM
I have been considering rebuilding my 901 side shifter for my track/AX car.
One box must fill all my needs. the motor is a 2056,with raby cam, running D-jet, probably around 110+ HP. I think that a rebuild while the motor is out is practical... suggestions for 3rd, 4th and 5th ratios. We run, Thunderhill 2-3 times per year, Buttonwillow once per year and Sears once per year....also Laguna at least as a DE event. thoughtful responses are appreciated. I want to make sure I don't run out of RPMs at the tracks with long straights like TH and BW. thanks |
ConeDodger |
May 29 2007, 08:50 AM
Apex killer! Group: Members Posts: 23,586 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Dan,
Sounds like you are at the same place I am... All dressed up and no 901 to go. There was a thread on this in the Paddock a while back. Someone had posted the available gears and ratios. One option I did not take, probably out of loyalty to Ron at IPB here in Sacramento was to take the engine down to Jerry Woods and dyno it and they would build the 901 with appropriate gears for what I want to do. Frankly though, I am wondering what has gotten in to you. You are always so GGR "points" concious. Now you have a non-stock cam and you are chattin' up non-stock gears... (IMG:style_emoticons/default/happy11.gif) Devil been whisperin' in your ears??? I think this is you at Marina last July... If that car gets any lower to the ground you will need a periscope to drive it. (IMG:style_emoticons/default/biggrin.gif) Attached thumbnail(s) |
Aaron Cox |
May 29 2007, 09:19 AM
my KA S box is amazing..... kept the ZD 5th for overdrive (and to drive to events at highway speeds)
race914 |
May 29 2007, 11:50 AM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
Lo-Fi Version | Time is now: 15th May 2024 - 07:59 AM |
