gas guage not working, when full it reads between 1/4 and 1/2 |
mattp |
May 30 2007, 11:09 AM
Member Group: Members Posts: 257 Joined: 22-November 06 From: westchester NY Member No.: 7,252 |
when full it reads between 1/4 and 1/2 but then gets accurate once fuel level drops to that level and below? Also if I turn the lights on it goes down about 1/8 of a tank?
Any ideas? |
smontanaro |
May 30 2007, 11:13 AM
Senior Member Group: Members Posts: 1,190 Joined: 3-June 05 From: Evanston, IL Member No.: 4,197 Region Association: Upper MidWest |
Bad ground somewhere?
Skip |
scrz914 |
May 30 2007, 11:22 AM
Member Group: Members Posts: 397 Joined: 21-April 04 From: Santa Cruz, CA Member No.: 1,960 Region Association: Central California |
There might be more than one issue here. But, you may want to check the sending unit that resides in the tank. Sometimes a little corrosion will keep the float from moving up and down freely. My guage stopped at 1/4 mark. I didn't know this until one day I ran out of gas with it still reading 1/4 left. I took out the sending unit (carefully) and there was just a little crud on it. Cleaned it up, put it back in and no more problems. Try this.
Ferg |
May 30 2007, 11:31 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
There might be more than one issue here. But, you may want to check the sending unit that resides in the tank. Sometimes a little corrosion will keep the float from moving up and down freely. My guage stopped at 1/4 mark. I didn't know this until one day I ran out of gas with it still reading 1/4 left. I took out the sending unit (carefully) and there was just a little crud on it. Cleaned it up, put it back in and no more problems. Try this. (IMG:style_emoticons/default/agree.gif) I just had this issue with the 75 I just sold. Removed the sender, took it all apart, (on small 4mm?? nut at bottom of sender, and the rest is press fit, slower pry it open with small screwdriver) the pole that the float rides on was all flash rusted, little WD40 and 1000grit and I had the float moving free again. Put everything back the way it was, and no further issues. If you plan on tackling the project (it's not hard) two things to be aware of. 1. Unhook the battery before you start 2. Take care and don't drop a bolt in the tank when removing the expansion chamber or the sender itself. Ferg |
echocanyons |
May 30 2007, 11:38 AM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
Be very careful if you sevice it, the thin guide wires on the sending unit are very easily broken.
On the plus side new senders are only ~100 dollars if you do break it. I think it is pretty common thing that the sender float sticks especially if you have a rusty tank. |
May 30 2007, 11:52 AM
I think it is pretty common thing that the sender float sticks especially if you have a rusty tank. (IMG:style_emoticons/default/agree.gif) that, and i'd check all the grounds just to be sure. the gauge itself rarely breaks ... (IMG:style_emoticons/default/bye1.gif) Andy |
mattp |
May 30 2007, 12:22 PM
how do I get at the sending unit? That was my first thought, Do I remove plastic catch tank and then ? thanks, Matt
tdgray |
May 30 2007, 12:54 PM
Thank God Nemo is not here to see this Group: Members Posts: 9,705 Joined: 5-August 03 From: Akron, OH Member No.: 984 Region Association: None |
Sending Unit is on top of the tank. Unscrew and pull out.
Do a search on this topic... there was a VERY good write up on how to recondition a sending unit. The search feature is your friend. |
914Sixer |
May 30 2007, 09:33 PM
Quick check for float is to tip it over. You should hear it go from the top to bottom. If stuck, shake vigorously. I have freed up several this way. No disassembly required.
Air_Cooled_Nut |
May 30 2007, 10:05 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
A little help:
http://www.icbm.org/cmgallery/thumbnails.php?album=58 |
rhodyguy |
May 31 2007, 09:17 AM
when you have the sender out and the tank is VERY low (i would empty it first) on fuel, now would be the time to examine the area in the bottom of the tank where the outlet and fuel return tubes are. you should be able to see the sock/strainer too. if the bottom of the tank is a mess be prepared to pull it. the whole process is much eaiser with the tank out to begin with.
k |
Lo-Fi Version | Time is now: 15th May 2024 - 08:49 AM |
