QUOTE(scrz914 @ May 30 2007, 09:22 AM)
There might be more than one issue here. But, you may want to check the sending unit that resides in the tank. Sometimes a little corrosion will keep the float from moving up and down freely. My guage stopped at 1/4 mark. I didn't know this until one day I ran out of gas with it still reading 1/4 left. I took out the sending unit (carefully) and there was just a little crud on it. Cleaned it up, put it back in and no more problems. Try this.
I just had this issue with the 75 I just sold. Removed the sender, took it all apart, (on small 4mm?? nut at bottom of sender, and the rest is press fit, slower pry it open with small screwdriver) the pole that the float rides on was all flash rusted, little WD40 and 1000grit and I had the float moving free again. Put everything back the way it was, and no further issues. If you plan on tackling the project (it's not hard) two things to be aware of. 1. Unhook the battery before you start 2. Take care and don't drop a bolt in the tank when removing the expansion chamber or the sender itself.
Ferg
